Originally Posted by mborner
With that, the leaning ability of the iTach can be greatly improved upon by the user. Two things will make a huge difference between success and failure.
1. It is essential that there is as little ambient light in the room as possible. Absolute darkness is best.
2. Make sure the remote you are learning from has brand new batteries.
Thank you for the tips!! Worked great for me.
