iRule - Page 108
post #3211 of 8396
I found the RS 232 codes for my older Escient music server. It says the power on code is ESCX1009. Is there a prefix or suffix to enter this code in the data field? I have tried \\x02 prefix and \\x03 suffix. I also read on one article that it should be followed by a carriage return. Does anybody have any idea's they could share with me. Thanks much.
D. Morse
post #3212 of 8396
D. Morse
Try \\x0D after the code (ESCX1009\\x0D)
post #3213 of 8396
Thanks for the try but that doesn't work either.
D. Morse
post #3214 of 8396
D. Morse
I just took a look at the escient documentationg and 1009 is power off. 1008 is power on and 1007 is power toggle.
Try ESCX1008\\x0D
post #3215 of 8396
Try ESCX1008\\x0D
I agree I found 2 sets of codes. My unit is what they called the fireball mx series. I will try that one and post back.
post #3216 of 8396
No go on that one either. I will try the 1008 with the other combinations I have tried.
post #3217 of 8396
Looks like the fireball uses these same commands. Are you using a global cache unit to connect to the escient? If so maybe check the serial port settings. According to escient they should be: baud rate 9600, parity none, databits 8, stop bits 1, flow control none.
If you are using IP, then make sure you have the correct IP address and port number. Looks like it uses a Dynamic address by default (good idea to change it to a static address) and the port number should be 251.
"The Ethernet port on the FireBall is automatically configured for external control using the
FireBall's IP address and port 251 (0xFB on the same subnet. The FireBall uses a Dynamic
IP address by default. The Dynamic IP address can be found using the Setup / Utilities/
System Information menu on the TV UI. However, it is highly recommended to set the
FireBall to a Static IP address when using Ethernet for external control because the IP address
of the FireBall must be hard coded in the control system program and could change if set to
Dynamic."
I'm out of ideas after this.
Good luck
post #3218 of 8396
Dynamic."
Good luck
Yes I am using the GC 100 and I did set and save to the baud rate etc. I will try some more this evening . Thanks for your efforts
post #3219 of 8396
Originally Posted by project_x View Post
No problem for me, the poster I was responding to seemed concerned about getting ripped off. I know that is not likely to happen. iRule is a legitimate business, and I trust all will ne resolved for him. In fact his difficulties are well documented in this thread, and in the signup instructions.
I am very satisfied with iRule and this thread, and recommend it to everyone I know. The power and flexibility of iRule, especially once we get 2.0 (feedback) and later an android port (cheap tablets). I see iRule as the glue that will let us integrate our home entertainment, automation, home security, sprinklers, landscape lighting,....with a infinitely customizable user interface. If you can imagine it, I think you can make it in iRule.
Ok an over dramatic response from my side I admit but im frustrated, ive paid a lot of money fro somethign that I cant use ... and im not sure what you guys define as "outstanding support" but to me, a company that cant respond to any of the 5 messages ive sent them over the last week+ is not good support nor good business ... I still havent received a response.
and searching a 300 page thread aint easy either ... could someone possibly point me to the page that discusses signup problems ? (think my license is linked to my paypal account which is mywork email addres and not my gmail email)
post #3220 of 8396
Yeah I've been there, this google account stuff sucks. You must use your paypal address to login, even if it's not a google account (you'll have to create a google account based on this non-google address in that case and use the newly created account, until you can get in touch with the support and ask them to move your credentials to your current gmail account). If the address you used is a google apps account you may use it with no problem tough.
Posting screenshot of the part where you get blocked would be usefull for troubleshooting.
post #3221 of 8396
Originally Posted by bucket23 View Post
I have done a new background for my main page, just a copy of the default background with some lines on it around a group of buttons. I have added some labels through the builder as well.
The problem is when I sync to my ipad the lines don't show and the rest of the background doesn't quite look right. Also one of the labels I added is missing the bottom line.
I have tried it on two different ipads, same issue.
I have also gone through and deleted all the buttons with no luck. I also tried deleting the custome background but the label missing the bottom line was still there.
Any help would be apprehiated.
Are your lines part of the background or did you add them as a graphic on a layer in Builder?
When you create a label with two lines, you must also change the cell height of the label from 1 to 2, or higher if necessary, depending on the size of the text and the size of your grid. If you'd rather have all the text on one line, change the cell width as required.
post #3222 of 8396
i get this screen after loging in with my gmail account ... richard.juchniewicz@gmail.com. MY paypal account i paid with is richard.juchniewicz@standardbank.co.za ... im sure thats what the problem is ? if irule wont get back to me maybe i should try pay via credit card using my gmail account and then ask paypal to return my other purchase ...
post #3223 of 8396
rjuch, it spells it out pretty well, here:
http://www.iruleathome.com/store/buy-now.html
Also, check here:
http://www.iruleathome.com/tutorials...e-account.html
It tells you how to convert your non Google payment to a Google account so that you can log onto your paid builder.
post #3224 of 8396
Also, check here:
http://www.iruleathome.com/tutorials...e-account.html is the correct link
post #3225 of 8396
I had the same problem, I had to sign up to gmail just to use the irule builder but my paypal account uses my original email address. I tried folowing the procedure listed on irules site to link the two together without success. I sent a support request in and had a reply in a few hours saying that they had activated my account.
I have had replies back from them for more than a dozen requests within hours, if not minutes. Twice I didn't get a reply and on resubmitting the request I had answers back promptly. Others have pointed out sometimes questions seemed to get missed, so if you don't get a reply within 24 hours to submit again. I am surprised you have had to send it five times, I suggest you give it another go
regards,
Graham
post #3226 of 8396
get this,
uremote is the new australian distributor. even thou irule website quotes price of $49.95 for the license for the builder software, uremote are charging $199. unbelievable
post #3227 of 8396
That would be right Barryjnr,
As usual the Aussies get shafted with quadruple the price...
Its just plain wrong
post #3228 of 8396
Thanks for the correction.
post #3229 of 8396
Originally Posted by barryjnr View Post
get this,
This doesn't sound right.... There have been a couple of strange things happening lately.
Itai I think you need to clear up a few things. Anyone that has contact with itai please let him know.
post #3230 of 8396
If I was Australian, I would google setting up a proxy to provide a US IP address. This would allow you to sign up for $50.
post #3231 of 8396
i tried the instructions on http://www.iruleathome.com/tutorials...e-account.html to create a gmail account for richard.juchniewicz@standardbank.co.za
but it says there is already a gmail account associated to this email ? any ideas on what I should try next ?
Australia dude : why dont you try purchase it using some sort of proxy that hides your ip ? or get someone in another country to buy it for you ?
post #3232 of 8396
True & thanks for the tip project_x,
But still for the average joesixpack wanting to purchase irule with A aussie IP address if what Barryjnr posted is correct $200aud is excessive no?
IMO I think iRule/ Itai should get onto Uremote as if true it appears Uremote arn't doing the right thing here imo...
From memory Uremote charge $700aud just for what they call A "Home Theatre Automation Package" (but appears they have removed some of there pricing) so perhaps irule have put A decent dent in there Uremotes income thus there now trying to reclaim some lost revenue
Jase..
post #3233 of 8396
omg im so excited i could pee, i got it working ... i eventually figured out that you can actually create a google account with a non gmail account and I already had one of these created long ago that I just had to reset the password for ... happy boy again, thanks guys... im sure i will be back with more questions
post #3234 of 8396
Lutron Grafik Eye GRX-RS232 anyone have xml control files. ive never created an xml file and the files on irules site not working.
Anyone know this or has xml files?
post #3235 of 8396
Hi all,
Got a question about how to structure the IR command for using X10 and IR543 device. Is there a delay that is necessary between Unit code and Function?
i.e unit1+delay(?)+ON?
Also... Is it not possible to do direct intensity input with X10 like you can with Insteon?
Alex
post #3236 of 8396
I just got my Ipad2 and want to get the irule app up and running. I want to control a JVC RS1x projector, a Pioneer SC-25 and an OPPO BDP-93 via RS-232. This is my first time doing something like this and I was wondering what else I need to buy. I looked into the Global Cache gateways, but I can't find one that supports (3) Rs-232 connections. It says that those Gateways are the only ones that are officially supported. Any help would be appreciated.
post #3237 of 8396
You will probably have to get a GC-100 12 and a Serial Itach. Or, there is a 16 port Digi port unit.
Alex
post #3238 of 8396
Originally Posted by osupike99 View Post
Hi all,
Alex
No, there is no delay necessary. In fact I use Robman's hacked X10 protocol that combines Unit and Function into a single command. Just get a JP1 remote, load the protocol and teach the combo commands to your remote.
No, there is no direct bright level. Some switches remember the last value though. And since each bright/dim command is something like a 7% change, you can usually make macros that get pretty close.
post #3239 of 8396
Is there a difference between IR543 and IR543AH? Because Robman's codes are for AH. Also... what would you suggest a delay be between the brighten commands?
Alex
post #3240 of 8396
Alex
Those options are expensive. Aren't there any reasonably priced multiport RS-232 gateways? Why are the IR gateways so much cheaper? I really want to go RS-232 if possible.
  Back to Forum: Remote Control Area
