Originally Posted by oxymoeron
Hello:
I have started a project after purchasing a home that included a ZPR68-10 pre-amp and PA1235 Amp, along with speakers throughout the house. Previously these were controlled under a Premise system, but I am moving to iRule. My daughter is helping me out in order to learn and help make progress while I am at the office.
We have an IP2SL on the network and connected via RS-232 to the ZPR68. iRule app running on iPhone4 finds the gateway. In the builder we have added the Xantech ZPR68-10 device. I believe Zellarman uploaded these and he has been a help in getting us started.
Does the gateway name need to be the same on two different iphones? (yes, the IP address is the same of course)
The main issue (oldest question in the book) is that after adding a test command in a panel and then syncing, we get the "Failed to connect to gateways!". I have read through quite a number of posts, but am still not clear as to the possible causes of this. Is this because the gateway is not communicating properly with the device or can I simply not communicate with the gateway itself?
Once we get past this, should we be able to get pretty far just adding the "database codes" to the interface? I don't know how to see the underlying commands...do we need to?
If anyone has specific experience with the ZPR68-10 I would appreciate knowing that for future reference and questions.
- Steve
Hello:
- Steve
Steve, I haven't used the builder in a while, so I'm really starting to forget some details with regard to setup, but I'll give it a whirl.
First off, I'll assume that you're aware that the ZPR all zones device means that the command issued will affect every zone, if you're looking to control a specific zone, then you'll need to use the device set up for that particular zone.
Next, in response to setting up gateways for each iPhone, you don't have to. When you select the sync button on either of your iPhones, there's three choices,
1) sync w/ iRule builder
2) backup gateways and
3) restore gateways
What you do is set up the gateways on one iPhone, once that is done, you back them up, then on the second device you select restore. Ironically, my wife just got an iPhone and I couldn't figure out why it wasn't connecting to the gateways after I synced it, thankfully it didn't take me too long before I realized all I had to do was this simple step. It's a great feature, I've heard that other similar apps require setting up the gateways on each device, as opposed to this 'copy' (restore) feature. We have three i devices, and a fourth on the way, so I certainly appreciate it.
And lastly, (and I'm not sure on this, but i think it's at least something close) when/if you have a page setup, but not all buttons are assigned a command, I think you'll get the red or yellow gateway icon in the lower right, though the error message you're getting, I guess is a little different.
Do you have devices that haven't been assigned a gateway, or buttons that haven't been assigned commands?
