Originally Posted by Jessev
I accomplished this (and much more) using XBMC on a dedicated PC. Once you have that, just enable HTTP control in settings and choose a web interface (I use wTouch) or make your own. Use a static IP for your HTPC and then add the device as an HTTP gateway and a page with the URL on it. I had mine working in no time
I'd love to be able to add this to my system. Would you be able post a 'step-by-step' explanation for a relative 'newby'?
Brian
