iRule - Page 204
post #6091 of 8390
I just thought I would throw out there that I just jail broke my iPad one on the latest ios and installed screen dimmer and it is awesome. I should have done it a long time ago. No more waiting for gateway connections and in general it has increased my battery life by a noticeable amount. Also installed an app called dimmer that allows you to turn the brightness down substantially more than stock.
post #6092 of 8390
Originally Posted by mborner View Post
Not on an iDevice. What tablet/phone are you using? An iDevice has to be jailbroken and the Cydia "ScreenDimmer" app installed.
Where about's is the download for Screendimmer?
post #6093 of 8390
This is where you can get it once your device is jailbroken.
http://cydia.saurik.com/store/
post #6094 of 8390
I was told my iPad has been jail broken.
Ive gone onto that link but I can not see where I pay for it?
post #6095 of 8390
If your iPad is jailbroken, the Cydia app should have installed automatically. The Cydia app icon is the Cydia app store.
post #6096 of 8390
I see. Mine can't be jail broken then, I was told it was. May be my OH has updated with out realizing. I will have to look into jailbreaking then.
post #6097 of 8390
Originally Posted by Wrekk76 View Post
Yes I created some webpages done with the jsonrcp api, so it nothing more then JavaScript. And I cant say I'm all that good with js.
Great work!
Wondering if you whant to share some code?
post #6098 of 8390
Got this press release from Global Cache today:
Jacksonville, OR, USA - March 6, 2012 - Global Caché, the leading independent manufacturer of IP and WiFi connectivity products for the control and automation market, announced today they have awarded their Value Added Reseller (VAR), US Distributor, and International Distributor top honors for sales of Global Caché products in 2011. The top VAR award goes to iRule, makers of the iRule smartphone and tablet app for control and automation, top U.S. distributor to SmartHome, the well-known distributor of technology for homes and businesses, and top international distributor to Comm-Tec, Global Caché Master distributor for Germany and France.
iRule sells Global Caché hardware as part of their total control and automation solution. The highly popular iRule app for smartphones and tablets is fully integrated with Global Caché hardware to provide a cost-effective, powerful control solution. "Global Caché products are an integral and important part of our product offering," said Itai Ben-Gal, iRule President.
Nice job iRule. And good news for our community of users.
post #6099 of 8390
appletv.
u guys using it in irule is it possible to call up movies through direct commands in irule meaning if i insert a pic of a movie can i add a command that will call the movie right up from my server?
thanks,
jim
post #6100 of 8390
This does sound awesome and I'll have to try it out tonight, but I wanted to offer my solution as well is this motion-based system doesn't work for everyone.
I used activator (installed by default with sbsettings) to set a short hold of the home button while the device is locked to launch iRule, whether it was running already or not. Activator allows all sorts of custom actions you can use to meet your needs
post #6101 of 8390
I've been searching for an answer to this, but I can't find one. Is there a way to send a WOL magic packet from a button? Seems like a useful feature to turn on my HTPC. I don't like the way WoL is currently implemented where it sends the WoL packet automatically when trying to connect to a gateway. What about when I just want to start the PC to use WMC or to listen to music? WoL is more reliable than an IR wakeup command since it works even if the PC is turned off completely or hibernating.
Second question is, is there a way to launch another app from a button in iRule? I have an iTunes button in my iRule that wakes up my computer and turns on my sound system and sets it to the correct input. But once that's done, I would like my iPad to automatically go directly to the iTunes remote app so I can control iTunes from there. Right now, I have to close iRule and then open the Apple Remote app manually. By the way, the iViewer/Commandfusion has this feature so you can launch any app from the iViewer remote.
post #6102 of 8390
I had my Tivo Premiere working over ip last night on my android tablet. This morning I realized the device I selected had no commands for zoom and the colored buttons. So I selected a device that had those commands. After I synced I tried to control the Tivo and iRule locked up. No big deal I thought, I will just change it back to the working codes and it will be fine. No matter what I do, any Tivo ip command locks up iRule. I reset my network and Tivo thinking maybe it was a network issue. The Tivo has a static ip which I used to create a http gateway with 31339 port. I must be missing something. Please help!
post #6103 of 8390
You may want to do a bit of research on your blanket "ANY APP" comment. It is up to the app developer as to whether or not they allow to be launched from another app. Sonos is a prime example of not being able to be launched. I suggest you take yourself over to irulecommunity.com and check out the upcoming features post.
Alex
post #6104 of 8390
HTTP or NETWORK GATEWAY? TiVo is network gateway.
Alex
post #6105 of 8390
Dimming function is already added to the app version that is about to be released. In the app settings menu you would enable Prevent System Lock and a dimming option will appear. This is only iOS 5 ability.
Alex
post #6106 of 8390
I`ve finally finish my house and my AV rack is on place. I Have bought an Itach ip2ir. But I have some problems with some "lag" when I`m tab on buttons. I`m also wondering how I can control the volume of my yamaha reciever fast. I`ve configured with the "hold to replay functions, and tried with different delays etc. But nothing works. Please help! I`m from norway so please be aware of my english;D
post #6107 of 8390
Try the suggestions from this post and see if it helps.
post #6108 of 8390
ipad3 (sorry i am not sold on the new Ipad moniker) + Irule = full 1080p graphics.... Maybe? any of you irule devs working on an app update to take advantage of all those little pixels?
post #6109 of 8390
I was using http. Figured it out right after I posted. Thanks tho.
post #6110 of 8390
I got my sc-35 working with irule with ip and rs232. I got all the feedbacks working (volume listen mode etc.) however I cannot get the input audio feedback. How can I get the input mode to display feedback? i.e. DTS-HD DOLBY HD etc. When I am watching a movie and I pause it the feedback displays Stereo and when I un-pause it displays auto surround.
post #6111 of 8390
yes you can launch the Remote app from an iRule button. It is described earlier in this thread in several posts. Check post #5610 for instance.
post #6112 of 8390
Ok I've searched the thread with as many search terms as I could think of, but didn't find an answer. I have two DirecTV receivers, both network-connected. I created a set of panels for the receiver, then copied those panels (so the pages are the same for both).
The first instance works great - nothing from the second. Doing some testing now I had to create a second Device (called Direct HTTP #2) duplicating the "DirecTV HTTP HR20-700..." device. But then I'll need to change the commands on each button (for the second instance of the pages) to map to the second instance of the DirecTV device in the device list. I changed one button and that worked - so at least I know what's going on... Is there any way to bulk-assign this? Or am I missing something very basic? Going through all the pages to replace each command would be a real PITA...
I would have thought that there would be a simpler way to copy pages to work on another device - especially since it's the same device type.
Jeff
post #6113 of 8390
Jeff
If you have Pro license you can share your original panel, click on Save from the file menu, then browse for shared panels and import your shared panel. When you do that, it will be imported with no commands at all.
Alex
post #6114 of 8390
Anyone here has experience on using iRule with an Oppo BDP-93 player? I use the GC-100-6 as gateway and even thought I managed to get the remote control of my lighting to work I can't get it to work for the Oppo (using IR). Wanted to try over serial as well but am not sure if my cable works. Does it have to be a specific type of cable? I have a null-modem cable with DB9 F connectors and plugged that into another serial cable with Db9 M connectors so I get male on one side. Wondering if the cables are different (cross over maybe?) as for the moment this doesn't work either.
post #6115 of 8390
I was controlling my Oppo BDP-93 over IR through my GC100-6 without issue. Switched o IP2IR and no issues. What device are you using in the builder? I'm using the user device OPPO BDP-93 Code 1 (PS) and it works fine. Have you added the OPPO device to your gateway properly?
Jim
post #6116 of 8390
Null Modem and cross-over are the same thing. I believe you need a straight cable for the BDP-93 if you don't have one you can use one of these to convert your cable to straight (or just buy a straight cable);
Hope this helps.
post #6117 of 8390
Jim
Yes, I have added the device to my gateway. Will have to check exactly what device I am using in the builder and get back to you. I can see by the blinking led on the gateway that my commands or something seems to arrive at the gateway, but the IR emitter doesn't blink, whereas the one for my lights blinks and works as intended (switched out emitters with the same result).
post #6118 of 8390
For what its worth I have my IR cable plugged into the back.
post #6119 of 8390
I am planning to buy a iTach Wired TCP/IP to IR but i need to manual input IR codes. Do i have to buy also the Global Caché's GC-IRL IR Learner?
post #6120 of 8390
That iTach has an IR learner built in.
  Back to Forum: Remote Control Area
