Sure thing. I see in the manual it says it uses the NEC protocol and custom code 0x06F9. Looks like the first byte is the complement of the second. Converting to decimal, you get 6 and 249, then enter into the MakeHex program plus 1 for ON and 9 for OFF to generate the pronto hex, then import into iRule. I think learning would be easier.
