You can make the button a link and have it go to any panel/page. Right click the button and select convert to link, then define where you want it to navigate to in the bottom left corner of the GUI.
My DirecTV button is a link, it turns on all required components, sets the components to the correct inputs and outputs and then navigates to my Directv control panel main page.
Just make sure you create a command (I named mine 'Keep Alive'), in your JVC network codes, then enter the command as 'PJREQ'. Then create an Entrance for the 'JVC Projector DLA-RS55 RS232' device and drag your newly created command to the Entrance. Make it repeatable=Yes and for 3.0-4.0 seconds (the JVC PJ's IP connection closes every 5 sec).
. krichter1, the final piece of the puzzle was you explaining that the new background 'must' be positioned before the 'buttonarea' background in the left window (so I had to move my new background image up). I have gone thru most of the tutorials and speed read all 300+ pages but I missed this fine detail. So far I'm getting the basic builder stuff - this is fun but tedious and I guess when I get more advanced I'll have to learn how to use some image editor package (I'll start with Paint.net) to design some of my own cool graphics. Thanks again -
