iRule - Page 251
post #7501 of 9755
Originally Posted by Jim Clamage View Post
Worked on this for a couple of very frustrating hours last night. Tried every port number mentioned above. I did get a green light on a network gateway with my IP address and ports 13000 and 48360, but no response from the BDP-93.
Maybe iRule support can work some magic with the Oppo guys to get this going.
Jim,
Any reason you can't use RS232 ?
Cheers,
post #7502 of 9755
Originally Posted by IGO2XS View Post
Also, while I have your ears I have my Oppo BD-93 set up with rs232 commands. I also have the feedback working as well. For some reason every now and then I can't get my commands to work. It looks like I am connected to the gateway when this happens, I end up resyncing the page and then it works. I am just wondering why I would loose connectivity.
any direction would be appreciated. Mark
Mark,
No idea on the lost connection ... sorry !
What feedbacks are you using ? I've got track number plus I've used the Verbose Mode command to get the elapsed track time counter, but I can't seem to get Audio Mode.
Cheers,
post #7503 of 9755
help please....
I am using the ir remote codes for my denon 3312ci using the Denon Receiver/Preamp AVR Series Main Zone All Models commands. all commands work but i can not find a return command. Tried the return command on denon 3312 codes but that one does not work. any help would be appreciated. thanks
post #7504 of 9755
Originally Posted by blkicevic View Post
help please....
I have a Denon 1908 and had to learn the return code via itach ip2ir and ilearn software, add this as a pronto hex code on the denon device and see if it works for you:
0000 006B 0000 00C8 0082 0041 0010 0011 0010 0010 0010 0031 0010 0011 0010 0030 0011 0010 0010 0031 0010 0010 0010 0011 0010 0031 0010 0010 0010 0011 0010 0031 0010 0030 0011 0010 0010 0010 0010 0011 0010 0010 0010 0011 0010 0010 0010 0011 0010 0010 0010 0031 0010 0011 0010 0030 0011 0010 0010 0010 0010 0011 0010 0010 0010 0031 0010 0011 0010 0010 0010 0011 0010 0031 0010 0010 0010 0010 0011 0010 0010 0010 0010 0011 0010 0010 0010 0031 0010 0031 0010 0011 0010 0010 0010 0011 0010 0030 0011 0030 0011 0010 0010 0B44 0082 0041 0010 0010 0010 0010 0011 0030 0011 0010 0010 0031 0010 0010 0010 0031 0010 0011 0010 0010 0010 0031 0010 0010 0011 0010 0010 0031 0010 0031 0010 0010 0010 0011 0010 0010 0010 0011 0010 0010 0010 0011 0010 0010 0010 0010 0011 0030 0011 0010 0010 0031 0010 0010 0010 0011 0010 0010 0010 0011 0010 0031 0010 0010 0010 0010 0011 0010 0010 0031 0010 0010 0011 0010 0010 0010 0010 0011 0010 0010 0010 0011 0010 0031 0010 0030 0011 0010 0010 0010 0011 0010 0010 0031 0010 0031 0010 0010 0010 0B44 0082 0041 0010 0010 0011 0010 0010 0031 0010 0010 0010 0031 0010 0011 0010 0031 0010 0010 0010 0010 0011 0030 0011 0010 0010 0010 0011 0030 0010 0031 0010 0011 0010 0010 0010 0011 0010 0010 0010 0010 0011 0010 0010 0010 0011 0010 0010 0031 0010 0010 0010 0031 0010 0011 0010 0010 0010 0011 0010 0010 0010 0031 0010 0010 0011 0010 0010 0010 0011 0030 0010 0011 0010 0010 0010 0011 0010 0010 0010 0011 0010 0010 0010 0031 0010 0031 0010 0010 0011 0010 0010 0010 0010 0031 0010 0031 0010 0011 0010 0B44 0081 0041 0011 0010 0010 0010 0010 0031 0010 0011 0010 0031 0010 0010 0010 0031 0010 0010 0011 0010 0010 0031 0010 0010 0010 0011 0010 0031 0010 0031 0010 0010 0010 0010 0011 0010 0010 0010 0011 0010 0010 0010 0011 0010 0010 0010 0010 0031 0010 0011 0010 0031 0010 0010 0010 0010 0011 0010 0010 0010 0011 0030 0011 0010 0010 0010 0010 0011 0010 0031 0010 0010 0010 0011 0010 0010 0010 0010 0011 0010 0010 0010 0011 0030 0011 0030 0010 0011 0010 0010 0010 0011 0010 0031 0010 0030 0011 0010 0010 0F12
post #7505 of 9755
Hey guys I have a couple of questions. I have had my iRule setup in operation for 7 months now and really enjoying the control. I do have the iPhone 5 now and I thought since iRule Builder has the iPhone 5 handset option I would go ahead and update it so I could enjoy the extra real estate on my screen. I looked back in the thread and saw the copy and paste recommendation so I did just that. i set up the new iphone 5 1136 x 640 handset and copied and pasted the panels from my iPhone 4 handset. I was able to copy all of the pages but now I have midget buttons on my iPhone 5 handset:rolleyes: I am not the sharpest tac in the box so if you could tell me what I have done wrong I would appreciate it.
OK, so you copied an iPhone standard resolution handset to the iPhone 5 handset. That will result in "tiny button" syndrome.
If your handset is highly customized (from the iRule default handsets), then you'll probably have to import the Retina buttons and drag/drop replace your mini buttons with the Retina buttons. It's a little monotonous, but shouldn't take you more than an hour or so to do even a fairly complex remote like yours.
If your handset isn't too customized, you can use the iRule template handset (File > New Handset) for iPhone 5 in your desired theme (with template devices) and then use Device Replacement to replace the template devices with your devices, then make changes from there to match your existing handset.
Depending on how complex your remote is, either could be viable options to get a new iPhone 5 handset going. The cool thing is, that if you're like me, you'll fool around with it for a week or two, so you can switch back and forth between the old handset for using the theater and the new handset for testing while you iron out the bugs.
Not sure about this one. If you're connected to the gateway and communication is successful (green gateway icon in lower-right, and green arrows on lower-left when you push buttons), then it sounds like a serial issue. Just because it's easy, there are a couple of things you could try. Delete and re-add the gateway, and see if that has any effect. Try disconnecting the feedback temporarily and see if that has any effect. You could also try power-cycling and then resetting the GC-100 or iTach. That's the easy stuff. The harder stuff is swapping serial cables and trying a different gateway or router to find the issue. Troubleshooting all this stuff can be fun, can't it?
SC
post #7506 of 9755
Originally Posted by Peter M View Post
Jim,
Cheers,
Peter,
Its not that I can't use RS232, although it would mean purchasing a new iTach to do that.
I do have it working now using IR with my iTach IP2IR, but I always prefer to use IP whenever possible. IP wasn't possible before, so I was happy to use IR. I have the BDP-93 hooked up to my network over Cat 5 already, so now that IP is possible, I'd prefer to be able to switch to IP and remove the IR connection from my rack and maybe get feedback someday as well.
post #7507 of 9755
ecrabb,
Any chance you could take the lead in trying to help figure out the Oppo IP/port connection issues with iRule we've been banging our heads against the past few days?
post #7508 of 9755
It may be that your iPhone 4 build was just a standard iPhone build, not one made for that particular phone. If so, you may not have used the Retina Display graphics (buttons and backgrounds), so the buttons look half as big as they should. Retina Displays have twice the number of pixels per inch, or four times the number of pixels overall. Trade in your buttons for Retina Display buttons and your backgrounds for retina Display backgrounds, and you'll likely see what you want.
post #7509 of 9755
I think the iphone 4 has retina too, but the #of pixels is different since the iphone 5 is bigger......
post #7510 of 9755
ecrabb,
Hi, Jim -
- The IP protocol is not the same as the RS-232, so stop the banging. wink.gif
- iRule has prelim protocol docs, and Oppo IP control will be integrated
- Test hardware on the way
In short, this is in motion.
Cheers,
SC
post #7511 of 9755
I thought I read that Roomie had the Oppo incorporated into their software. I have no idea if competition in the marketplace has an effect in this instance . . .
Willie
Posted this at almost the exact moment SC posted his response above. Awesome news. I look forward to retiring one more IR piece.
Edited by Willie - 12/20/12 at 2:25pm
post #7512 of 9755
Originally Posted by ecrabb View Post
Hi, Jim -
Cheers,
SC
Great to hear, many thanks ecrabb.
post #7513 of 9755
Thanks for the info but it was not successful :-( bummed
post #7514 of 9755
Hi blkicevic, try this one.
0000 006c 0000 0020 000a 001e 000a 0046 000a 001e 000a 001e 000a 001e 000a 0046 000a 0046 000a 0046 000a 0046 000a 0046 000a 001e 000a 0046 000a 0046 000a 001e 000a 001e 000a 0661 000a 001e 000a 0046 000a 001e 000a 001e 000a 001e 000a 001e 000a 001e 000a 001e 000a 001e 000a 001e 000a 0046 000a 001e 000a 001e 000a 0046 000a 0046 000a 0661
post #7515 of 9755
Hi, Jim -
Cheers,
SC
Great news ... thanks Steve !
Cheers,
post #7516 of 9755
Hi, Jim -
Cheers,
SC
Steve ... another question ... will it be a device with commands and feedbacks, or a module ?
Cheers,
post #7517 of 9755
I got the GC-100-12 and am about ready to pull the trigger and jump in with you guys with the pro license. For the time being I am going to run the theater on my iphone and/or laptop but eventually I want an ipad for the ultimate setup. For those of you using an iphone 4 or similar screen size device:
  • how would you rate the functionality of irule for a dedicated home theater setup?
  • How many "buttons" can you fit on one page?
  • How many pages do you have to incorperate to have total control over an activity like "Watch Blu-Ray" or "Watch DirecTV"?
  • Can some of you possibly share some screen shots of your remotes? The irule site is kinda scarce on pics of the iphone interface..
post #7518 of 9755
I use Kindle Fire running a custom ROM now in the theater but have a fully functional ipod layout that is used from time to time and in the rest of the house.
I use Steve Goff's steampunk templates
I use 3 pages for my DTV control:
I find them easy to use. I am not a channel surfer, pretty much live sports and recorded shows for me. I know some people miss the tactile buttons of a normal remote. I do sometimes, but the convenience of 1 remote that I can fully customize on my own is worth the trade off. I know my wife never would have used the PS3 for Netflix without iRule.
I don't have an easily accessible screen shot of my Hands Free panel for ipod, it looks similar to my Kindle version. I use this almost exclusively when watching recorded content. No need to look at the remote, swiping left activates the FF command 3 times for a quick skip of commercials and a tap on the screen hits play when ready.
post #7519 of 9755
Hi Nick,
Here are some examples of my setup on iPhone/iPod - these are not retina....
I made the activity buttons nice and big for the small screen. My directv page is about as many buttons as I like to fit on a page otherwise hitting the wrong button becomes a real possibility. I use two drawers for the directv colours and number pad as you can see above (really love drawers!!).
On the Blu-ray page I can set my volume discretely to about -15dB, about as loud as my wife can handle in the media room.
-Mark
post #7520 of 9755
Thank you SS and SQM,
Those interfaces look awesome! I'm In. Off to get a license now.
I'm sure I'll be back with questions soon.
post #7521 of 9755
In so many ways iRule looks like it is the web-based incarnation of NetRemote 2, which was published by Promixis to work with Girder. Do the developers of this software have their origins with Promixis?
Willie
post #7522 of 9755
no none of them
post #7523 of 9755
Yes, the iPhone 4 has a retina display, but I think you can use the standard build and it will just scale, like any other app.
post #7524 of 9755
That is an awesome idea!
Mark
post #7525 of 9755
I started today with the pro license. Its a lot to digest all at once.
Is there any reason not to use retina designs in the iphone 4? I saw retina and non retina designs so i was using the retina versions.
post #7526 of 9755
If you use non retina buttons on a retina screen, the buttons will be smaller.
post #7527 of 9755
This worked!! Thanks
post #7528 of 9755
Is it possible to control tellstick duo from irule?
post #7529 of 9755
Yes, if you use EventGhost with the TellstickDuo plugin and the Broadcaster plugin you can. Works great!
post #7530 of 9755
For those who are using those gc10012s off ebay, how did you find out its ip address? I cannot see the device when i type in the default address in my browser. I shorted DB9 pins 2-7 and plugged in, and device still wont come up in browser. I tried a crossover cable and straight into my network.
Any ideas?
  Back to Forum: Remote Control Area
