Dave,
If you used Fing to scan your network, you can set the IP address to one that was unused (one NOT in Fing, but in that range), and a netmask that matches your computer or Android or iOS device. Or, you can just tick the "Enable DHCP" button for starters. That will tell the iTach to get its IP address from the router.
SC
