Originally Posted by NicksHitachi
For those doing lots of channel feedbacks, how could i apply those to more than one HTTP device?
IOW when i try to assign the channels only device in the Gateways tab of irule handset it shows "in use" why cant you assign one device to multiple gateways? The gateway shouldnt care how many are connecting right? There is no way im doing all that work over to get channels on every directv receiver thats rediculous!
Solved this problem on my own.
To get the feedbacks to work in multiple panels without re-doing all the feedbacks, do this:
- Set the feedbacks and associated device(s) to "shared" in their properties box at the bottom left.
- Assign the associated device to one gateway on one handset since irule won't allow to assign to multiple.
Thats it the feedbacks now work in two of my seperate panels concurrently. IOW the same feedback is put into multiple panels and works without being duplicated, all you have to do is set it to shared.
