Is integration of an ELAN SYSTEM6 possible with irule?
If so how is it done?
Are there codes in the library for ELAN Stuff?(cant search right now)
) but I figured you'd get the same response and then some. I'm still waiting to see what the Insteon iRule module looks like. Instead of using set Brightness/Dim levels, I use the following commands from my device code to manually brighten/dim a particular device (except for Full On):
