iRule - Page 297
post #8881 of 9754
Originally Posted by s.bradford View Post
Don't have an iPad, but comparing performance with a nexus 7 gen 2 to an iPod 4 gen, the performance on Android is clunky at best.
Page transitions are laggy, and panels are slow to change. The nexus has several times the horsepower of the iPod, so I can only assume there is very little optimization being done on Android.
There are also a good number of missing features. It's a 1.x release and has a long way to go.
Originally Posted by CentralCoaster View Post
Is that really true? How does a 2nd gen. Nexus 7 stack up against a late model iPad?
_____
Axel[/quote]
IDK, but I'm comparing my gf's iPhone 5 to my Samsung S2 and a Kindle Fire. Maybe not a fair comparison as the iPhone is newer, but the iRule had a lot of glitchy issues with the Android I had to program around. The iPhone on the other hand just plain worked, smoothly, loads fast, no lag. I have a ton of pages and feedbacks on my system. It's no secret that they update the program for apple devices first and then try to play catch up with the Android.
Thanks Guys,
I guess, I will hold off with getting an Android device for a bit. Maybe Apple will come out with a retina iPad mini very soon after all.
____
Axel
post #8882 of 9754
I am an android guy mainly, but iRule seems to be what I really need to control my set up. Would a 1st or 2nd gen iPad be adequate (or more) for running irule speedily?
post #8883 of 9754
I have a 1st gen. iPad and iRule runs on it flawlessly. I see no difference in speed between it and my mini.
post #8884 of 9754
I want iRule so bad so that I can operate my entire house (AV + lights/security/energy) ONE app, but that tv guide feature of roomie is too hard to beat and is worth running 2 apps to control everything. iRule....GET THAT FEATURE
post #8885 of 9754
You realize roomie has gone to a subscription arrangement, right? Would you be willing to pay iRule a monthly/yearly fee for guide data? This data involves real costs to deliver, and since I already pay TiVo for it, have no need for it in iRule.
post #8886 of 9754
Yes. I use roomie today and the subscription costs literally mean nothing to me. $17? Are you kidding me? If iRule were to have this feature at that price, it's a NO BRAINER to me. iRule already has a couple head scratchers in there, such as modules are paid PER HANDSET (like Sonos module), but again, to me, it's not a problem.
I'll be testing out the iRule builder and building a remote just for the fun of it and also in the event I make the switch. I'm on the border because I like the customizations and the fact I can do everything on iRule. But that HD Guide feature on roomie is simply killer.
post #8887 of 9754
Has anyone asked iRule if they are planning to drop support for iOS 5? The iPad 1 can only run iOS 5 and if that is dropped I will lose my dedicated iRule remote since I don't use my iPad 3 for iRule.
post #8888 of 9754
I'm sure they will eventually, but i hope it isn't any time soon. It was just earlier this year that they dropped support for 4.2.1 (and as a result i had to buy a bunch of 3g ipods to replace all of my 2g's). If they drop 5 soon and i have to go replace all the 3g's i just bought with 4g's i'm not going to be a happy camper. According to Itai though, it's not their decision, it's forced on them by apple.
post #8889 of 9754
[quote name="s.bradford" url="/t/1351981/irule/8880#post_23801139"] the subscription costs literally mean nothing to me. $17? ... iRule already has a couple head scratchers in there
Agreed, but you might be surprised how many people got bent over the subscription fees (granted the dev could have handled it better).
Even iRule bent some folks when device limits were somewhat silently introduced in newer versions.
While I'm less than thrilled that design of my remotes is dependent on iRule's servers, IMHO it's the best game in town at the moment, even with the clunky and repetitive process of building remotes.
post #8890 of 9754
Maybe they will go the same route as Roomie and have a dedicated app (older version) just for iOS 5....as long they don't charge for it as a separate app.
post #8891 of 9754
It is primarily up to Apple. With each new version of XCode comes older platforms you can no longer compile for. Of course, you need the newest version to develop for the latest and greatest, and it has become increasingly more difficult to use the same project in multiple versions of XCode. Keeping two code bases, with one solely designed for legacy platforms is simply not cost effective.
As a hardware company, Apple has even less motivation to allocate resources to keep the current dev platform compatible with legacy devices. When there's a new, better way, the old way is deprecated. That's just Apple. Figure three to four hardware cycles until devs will no longer be able to keep current and still target builds for your device/os version.
post #8892 of 9754
can some one please point out where can I find the listening mode buttons for the onkyo/integra for the retina display.
post #8893 of 9754
You might want to read that fine print again. I have the iTunes module installed on 3 handsets and I've only paid once, legally. I run the pro version so it may be different for the standard version.
post #8894 of 9754
Has anyone used the Hue lights and been able to control them with iRule? I am looking for the most cost effective route to being able to control everything in my theater. The lighting is next!
post #8895 of 9754
Handset is what it is in the builder and is defined by either unique resolution or GUI. So if you have 10 ipad retinas syncing to the same GUI, that is ONE handset. Doesn't make a difference whether you have Pro or Basic license.
Alex
post #8896 of 9754
I would like to understand how to use variables and appears there are no instructions/tutorial on the iRule Support site?
I think Variables will help me do the following:
- Have one panel per device that I am controlling: Tivo, Blue Ray and Apple TV
- I will have a home page with 6 Buttons... One set for controlling my 3 devices when I am watching from Den TV and another for when I am watching my bedroom TV
- The same device panel will be used for both Den and Bedroom but a variable will be passed from the home page so it knows: which TV to control (Den or Bedroom), which HDMI Matrix option to select and if Zone 2 on the AVR needs to be turned on if in bedroom
Will this work using variable?
Can someone give me a jump start on how I would do this? Or point me to a tutorial?
Thanks in advance,
Doug
post #8897 of 9754
Thanks in advance,
Doug
Doug,
Take a look at the manual found on iRule's website: video.iruleathome.com/training/UserManual.pdf
Alex
post #8898 of 9754
Thanks osupike99.... Looks like the variables will work the way I need it to...
post #8899 of 9754
Originally Posted by bryansj View Post
This problem is back. I had re-installed VC++ as well as updated to the latest version of EG. What is weird is that a reboot doesn't seem to fix the problem, but exiting EG and restarting it does. Where on the EG forum did you find reference to this similar situation?
I've uninstalled EG, reinstalled the latest EG, and deleted and added back the Broadcaster plugin from my config. I'm about ready to switch to MCE Controller, even though EG broadcaster works fine on my personal system. The only difference between the two systems is mine is Win8 and the other is Win7. I may also try changing the port from 33333 to something else.
The problem is back. I'm going to switch the system over to MCE Controller program. If that doesn't work then I'll go with IR.
post #8900 of 9754
Is anyone else having issues with iRule on an Ipad 1 since the latest updates?
I have been running iRule on a 16GB Ipad 1 for years now with no problem.  Ever since the last two updates I have the following issues.
Overall the App is not as responsive, ie.. press a link and it is slow to switch to the linked panel.
When switching between apps and back to iRule it takes a few seconds for iRule to become responsive and or connect to gateways, this used to be almost instant.
50% of the time when switching back to iRule, iRule locks up then quits.
I know we are up to like the ipad 5 almost now but my ipad 1 is used almost exclusively for iRule and has been fine until now so I hope this is not a sign of things to come.
Any ideas or similar experiences?
post #8901 of 9754
Sorry for the dumb question but can somebody explain the difference between pinned and unpinned drawer.
post #8902 of 9754
pinned means the drawer is always open. Unpinned means you have to open the drawer manually.
post #8903 of 9754
Thanks,no where did I see that explained like that .
post #8904 of 9754
Can anyone shed some light why the iRule Device codes for JRiver don't work for me?
I have set up JRiver using a Network Gateway, put in a port number, my JRiver Gateway symbol Green, yet when I try one of the JRiver device commands nothing happens.
post #8905 of 9754
JRiver must be set up as an HTTP gateway, using my device or another from the library.
post #8906 of 9754
post #8907 of 9754
Happy to help!
post #8908 of 9754
Hi guys,
I have a Denon AVR-1913, Global Cache iTach and iRule.
My problem is that I am not able to have control of iRadio via irule.
I used the command NSE0 up NSE8 but is not working.
Algume could help me.
Thank you.
Marco
post #8909 of 9754
Yeah I'm also having theses issues. My pages sometime don't swipe at all, slow transition from other apps back to iRule with it sometimes just hanging and crashing. IRule also crashes occasionally if it sits on my homepage for hours with no activity, I'll walk by my 1st gen iPad and the app has crashed. The Sonos integration also causes many hang ups and crashes. It does work flawlessly on my DirecTV page. It seems it happens when trying to go in and out of the app or using Sonos. You mentioned the gateways, I also see only a white gateway symbol at times and I find I need to go to the beginning and deselect the panel and then it's fine again. But that is frustrating and the WAF is low at that point.
post #8910 of 9754
Similar issues here with iPad1.
  Back to Forum: Remote Control Area
