Interestingly I had assumed the front page of this thread was wrong re the DACs being 32 bit in both the 55 and 57 since in the 35 and 37 the former used a 24 bit dac. Not only that but the difference was larger as the 37 used multiple 2 channel 32 bit dacs vs one 8 channel 24 bit one in the 35
Took a look at the amp tech file (promotional material) PDF online for the 55 and 57 today and it states they both use multiple 2 Channel 32 bit dacs (AKM)
It sort oc makes sense as both the 55 and 57 have changeable filters (sharp,slow etc) which I think are built into the dacs
Presumably this means the 55 is much nearer to the 57 sq wise than the 35 to 37 was ?
Also did the 35 have a cut down mcaac vs the 37 ?
Seems to be the same between 55 and 57 ?
