Originally Posted by PV Boy
My SC-55, which is working well generally, has repeatedly (every couple of days) refused to respond to the iControl AV2 app on various of my IOs Apple devices, an iPhone 4, an iPhone 3 GS, and 2 iPads, 1 first generation, and the other an iPad 2. I get an error message code 57113 and "check your device" message and cannot reconnect until I go to the receiver, pull the power cord or hold the power button for about 10 seconds, then turn the receiver back on. Anyone know what the bug is? and, of course, how to fix it. Very annoying to have the machine repeatedly lose remote connectivity. The receiver is connected to my home network via ethernet and two hubs back to my Apple Time Machine Station/Router.
Also, I could not get the Zone 2 hook-up to run for more than about 20-30 minutes without shutting off when I was connecting the Front Wide speaker outs via a Niles Impedance compensated speaker switch and volume control with two sets of small 8 ohm bookshelf speakers. It continued to shut down even after I changed the hook-up to one using my vintage MacIntosh 2100 power amp connected to the ZONE 2 Pre-amp outs on the SC-55. There must be some thermal overload circuit to prevent you from conncecting more than one set of speakers to any Zone 2 configuation. It's kind of ironic, too, because my old Integra AV amp, jury-rigged to switch component video through a Zector a/v switch would run all day via its multi-source pre-amp outs connected to multiple speaker pairs via the Niles. Not so, for the Pioneer in Zone 2. When I switched the MacIntosh to the ZONE 3 pre-amp outs, the system plays perfectly, with no shut-offs. Anyone know why this is?
Any help or advice about the repeated IOS remote app problem would be helpful. Is this problem wide-spread with Pioneer Air Play receivers. Also, the receiver won't play any podcasts, even though the web site lists hundreds you can connect to. Why is this? The internet radio stations play OK, though.
For zone 2 powering off, see page 81 auto power off, turn zone 2 to off. If you read the section very carefully about 20 times you will understand
For icontrolav2 problem, yes, I think it is a bug in the ipcontrol firmware in the receiver
I can't tell you how to fix it, but I can tell you how to reset the receiver without unplugging
With the remote, select network standby off, turn the receiver off, turn back on, set network standby back on
I would call pioneer customer service and complain
I think I had better luck with a fixed ip address for the receiver and next time it locks out icontrolav, I will see if the ipcontrol section is still alive and maybe I can figure put what is going on
