AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Pioneer Elite SC-55/SC-57 Owners Thread
The "Official" Pioneer Elite SC-55/SC-57 Owners Thread - Page 105
post #3121 of 3857
Originally Posted by purdyd View Post
Really? Are you saying mcacc completely fabricates the reverb after curve?
I doubt that
unless it re-measures AFTER it has made the adjustments (i don't remember, it's been a LONG time since i played with reverb), it can only be a "predicted" curve...
also don't ignore the smoothing comment...
post #3122 of 3857
I think it does measure AFTER
And I don't know what you mean by smoothing
It appears to me there is NO smoothing in the reverb or group delay graphs
Perhaps you should refresh your memory with mcacc, but i think you are right, if you are talking about Audessey but I am not as familiar with the results from its room correction curves
post #3123 of 3857
Interesting to hear Dolby extolling the virtues of an apodizing filter for audio. Are there any other receivers that have this filter besides the Pioneer totl receivers?
post #3124 of 3857
Any further word on a new firmware update?
post #3125 of 3857
i would start with 80, and unless proven by measurements to be mo' bettah at 50, stay at 80... i would NOT do this strictly by ear, as you are already predisposed to "want" a certain outcome... i would take a somewhat educated guess that 80 will be better, simply based on years of 'sperience setting up systems (not to mention having seen heaven knows how many graphs from others)...
as noted earlier... you need to think of your system as a whole, not as a
"am i getting the most out of one piece of it"...
for instance, my mains have measured (not spec'd) in room response well into the 30's... they are crossed at 80, for two very big reasons...
- crossing them there allows me to work with the two dominant modes in my room with the subs... with the combination of positioning/eq (primarily eq, including other tweaks), i make those modes "go away" in the end result... solving this issue can't be done by "ear", at least not by me, since in this region, peaks are very evident to my ears, but dips/nulls aren't... i am not alone in that, judging by ancdotal reports from many who report "i lost my bass when i eq'd my sub"... no, the user didn't "lose their bass", they lost the mountainous response curve, and likely eliminated a monster peak that they were identifying as "good strong bass"...
- regardless of the measured response (and if by some miracle the mains placement works well with the room modes, which virtually never happens), the mains cannot even dream of producing that 40-80hz octave with the authority that the subwoofers do... also, relieving the mains of producing that octave will allow them to perform "better"...
there's more, but those two reasons alone speak favorably of edging your xover points as high as they will go* vs. as low as they will go...
subwoofers have one job, and that's to produce 2 octaves (or in the case of some of us, 3 and a bit more )... let them do it...
* assuming no localization, etc. and when it comes to localization, keep in mind that many times when people loclaize their sub, it's because of outside influences (rattles, etc.), not because of the frequencies coming from the sub...
I thought only 80hz or higher was recommended ?
as 50hz on Pioneers also acts as a low-pass filter @ 50hz for the LFE channel as well doesn't it ? - which removes a lot of the LFE channel .... or was that changed on current range ?
there is a lot of LFE content >50hz ...
post #3126 of 3857
is this for real?
post #3127 of 3857
Originally Posted by rswelter View Post
is this for real?
Yes, there is a firmware upgrade, not sure what it fixes
post #3128 of 3857
I can't update because the option Firmware update is disable.
I tried many times to reset the avr following these steps:
- unplug all the cables (power, hdmi, network and the Bluetooth device)
- wait a few minutes to empty the capacitors
- plug only the power cable
- reset the avr
- turn off the avr
- plug the TV cable
- turn on the avr
- check the option Network Information
Even if there is no network connection, when I check the option Network Setup it displays a dialog box with the message Network Setup. Applying settings. and the display is frozen.
When the option Network Information is disable, the option Firmware update is also disable.
When the receiver is not able to detect the network, it also is not able to connect with an iPad via Bluetooth (AS-BT200). On the avr display it shows Starting. When it shows Starting nothing works.
post #3129 of 3857
Originally Posted by amp74 View Post
anyone know why id get a "file format error" message when trying to load any kind of podcast from the internet radio menus?
Was this addressed? I have the same problem with some Internet Radio stations that I add through the Pioneer Vtuner site. Some stations work and some give me the File Format Error message even they all MP3 based.
post #3130 of 3857
- reset the avr
- turn off the avr
- plug the TV cable
- turn on the avr
Don't try to update over the Internet if you're already having a problem with the network connection. It won't work. Go to Pioneer's website and follow the instructions for copying the firmware onto a USB flash drive and update directly. You'll need to look up discontinued products because the SC-57 is no longer the newest.
post #3131 of 3857
Trying to update over the Internet is pointless anyway. I just now updated my firmware via the flash drive. When I selected "Update over Internet", it said I already had the latest version. Pfft...
post #3132 of 3857
Found this for our SC-55/57's from the Pioneer website:
CHANGE HISTORY
MODELS: SC-57/UXJCB, SC-55/UXJCB, SC-1526-K/CUXJ
Version : 1-203-086-703-069
- Enhances connectivity when using an HDMI extender
- Performance improvements
For me this is one of the major reasons for upgrading my receiver to the SC-57. The main firmware can now be finally upgraded at home. I was sick and tired of disconnecting everything from my VSX-94TXH, hauling it to an authorized service centre, waiting for 2 weeks, then hauling it back and reconnecting it. I did this 3 times and I really got fed up. One time they even did not have the latest firmware with them and I traveled a long way for nothing.
Thank goodness that the SC-57 came along to meet my home theater needs.
Also, sure it would be nice to have an SC-68, however, the only thing that would have interested me would be the 4K2K passthrough feature but my fellow forum members here stated not to worry because:
1- there is no 4K2K content yet and 2 - all I would need is a dual HDMI 4K2K blu-ray player and go directly to the tv for the video and directly to receiver for audio
plus
3 - the SC-68 cost a lot more for features that I will not be using and 4 - received my SC-57 35% off Canadian MSRP on boxing day.
Thank you Pioneer
post #3133 of 3857
CHANGE HISTORY
plus
Thank you Pioneer
Performance improvements is sort of vague
post #3134 of 3857
Hi
Have a LX85(SC57) to play with and have a some question.
Then i enable the PCLS the volume lowers, and i cant get my android phone to stream to the amp. This was not problem with the Onkyo 1009.
Thanks in advance
post #3135 of 3857
I can’t update because the option “Firmware update” is disable.
- reset the avr
- turn off the avr
- plug the TV cable
- turn on the avr
- check the option “Network Information”
Even if there is no network connection, when I check the option “Network Setup” it displays a dialog box with the message “Network Setup. Applying settings.” and the display is frozen.
When the option “Network Information” is disable, the option “Firmware update” is also disable.
When the receiver is not able to detect the network, it also is not able to connect with an iPad via Bluetooth (AS-BT200). On the avr display it shows “Starting”. When it shows “Starting” nothing works.
When you say that you "reset the avr," exactly what do you mean by that? Are you resetting back to factory defaults? If not, try that. The procedure is on page 61 of the manual and it requires holding down the "enter" key on the front panel while pressing the "on" button. That resets everything to factory defaults.
Although I'm not sure it will make any difference, you might also consider rebooting your router, reserving a specific IP address assigned to the AVR's MAC address at the router level, or both these things. Once you've cleared the error you might also think about assigning the AVR a static IP address. Everything you've done so far is limited to the AVR. You might try looking for the culprit elsewhere in the network.
post #3136 of 3857
Agreed. Had same problem with the Rhapsody update.
post #3137 of 3857
Yes, I reset the avr following the procedure described in manual. There are 2 options Reset and D. Safety (if you use Up Key). The option D. Safety is not documentated.
My problem is that the option Firmware update is disabled, so, I don't have access to the option Update via USB and I can't update.
post #3138 of 3857
Like the title says, I just pulled the trigger on my first new receiver in over a decade. Man, I can't believe what these things can do now. I've owned an Elite Blu-Ray for a couple of years, and am now installing Elite in-wall and in-ceiling speakers.
I've been dealing with my local Elite dealer, and he told me that there were some great deals on the discontinued models. It was either the "55", or a VSX-53. With so little difference in price, I went with the bigger one.
I just hope I can figure out and utilize what this thing can do.
Thank you everybody for your help.
Shawn
post #3139 of 3857
Well I did update and it didn't blow up or reset any settings
Not sure what performance upgrades have been implemented
I am hoping for a little more stable network connection
post #3140 of 3857
Hopefully. Although I applied the firmware a few weeks ago and I still continue to get the periodic HDMI lockups that I can clear only by cutting the power and allowing the receiver to reset. It works, but it's a pain. It's happened twice since the update.
post #3141 of 3857
Originally Posted by Vallhall View Post
Hi
Thanks in advance
Have to bump this
So can anyone explain to me why i cant stream from my droid phone to the pioneer?. The Pioneers lan connection is cabled.I use Pioneers icontrol app from my droid phone
Plz help me before i send it back again
post #3142 of 3857
Have to bump this
I'm not sure you can stream a droid to the SC-57 without a Bluetooth adapter. Airplay works only with Apple products. I can stream a Blackberry to the SC-57 via Bluetooth. And iControlAV is not a media streaming app.
There might be a way to get the droid to appear on your network as a windows media server, and then you could see it from the HMG menu, but it's doubtful and in any event I don't know how to do it.
EDIT: I take that back. I read an article on CNET about streaming to a Pioneer receiver from an Android device using the "DLNA-friendly Skifta app" and accessing the droid from the HMG menu. I don't have a droid so I can't test it but you might want to check it out.
post #3143 of 3857
Just updated my SC-57 to this firmware last night. Previously, I had an issue with video syncing problems with my PC connected to the receiver via HDMI and outputting to my TV via HDMI CAT6 extender. The video image will drop after couple seconds, sync back up, then drop again in an endless loop. To get a stable signal, I had to connect the HDMI extender directly to the PC to the TV. However, I had no issue with a PS3 going through the receiver with the HDMI extender. So to workaround the issue, I bought another HDMI extender.
With the new firmware, the issue is now resolved. So now I have an extra HDMI extender I need to find something to use with.
post #3144 of 3857
Many many thanks, i will look into that.
On the Onkyo you could stream both from PC and droid phones with Onkyo android app to the receiver...much more userfriendly than Pioneer
post #3145 of 3857
You can stream using dlna I haven't used a droid phone, but have used my iPad
You can also control a dlna server output to the receiver using dlna remote capability
It should be as simple as finding the right app
post #3146 of 3857
Skifta is a free app. You can find it here. https://play.google.com/store/apps/d...ta.android.app Ironically, the screenshot of the app shows an Onkyo receiver among the audio destinations.
post #3147 of 3857
A european review of the Sc57 (LX85).
http://www.homecinemachoice.com/news...le.asp?a=10421
Big thumbs up.
post #3148 of 3857
I have the 55 and have been trying to hook up a second pair of speakers to essentially just play the same audio as in the main listening room but in another room too.
Seems this should be relatively straight forward but I've not been able to get the second pair to work.
The manual is not much help here with all it's talk of zones and B speakers.
I've hooked up the second pair of speakers per the instructions but no sound to the second set...
Thoughts?
Thanks in advance.
post #3149 of 3857
Thoughts?
Thanks in advance.
I know for zones, the source must be analog, AirPlay or home media gallery
No hdmi or digital in
post #3150 of 3857
Big thumbs up.
That is not a very competent review. It insistently refers to the class D amplification as ICEpower, which Pioneer dropped last year.
AJ
