So I'm FINALLY getting my AVR back. Apparently it was a firmware problem and all the hardware is fine. I have the wireless adapter already set up, but I don't really have a proper network at home and I never used networking through the AVR or the adpater before.
Now I'm a little paranoid about the firmware - should I just not connect the adapter until I'm sure I'm going to use the networking function on the AVR? Would I be missing out on anything? My understanding is that Pioneer doen't often update the firmware, unlike Oppo and other electronics companies that seem to do it fairly regularly.
JD
JD
Originally Posted by jd_alpha
Thanks for the suggestions. Unfortunately, the AVR won't even go into standby mode so I can't try the hard reset. I'm sending it in for servicing. Once I have everything unhooked from it, I'll try to power it up one last time on a different power circuit just as a last check to see if it's an external problem.
At the time of the failure I was running it a - 20 db on the volume dial and it certainly wasn't at what I'd call a loud level. It's also in the bottom slot of an open rack with no other equipment near it, so I don't think it could have overheated. D3 amps run cooler as well, right?
Before I got my new speakers I asked around AVS if the SC-57 could handle a Monitor Audio Gold 5.1 speaker set-up and the consensus was it should have plenty of power and there should be no issues.
I really suspect it was a "sneaky" power surge type issue.
Anyone know of a fool-proof surge protection set-up (or at least "nearly" fool-proof)?
- JD
- JD
Originally Posted by ss9001
hoganj1 mentioned this as well.
There is a hard amp reset procedure you *could* try. This is straight out of the service manual for the SC-09 but worked for all the previous Ice amp based models, prior to the new amp design. I don't know if Pioneer changed the software code for the new amp design or not. You could try this:
During Standby mode, simultaneously press and hold the " (DOWN)" and "ZONE2 ON/OFF" keys for 2 seconds.
The above procedure is to release the amps from the error lockdown but if the fault still exists, it probably will go back into protection. On previous models, it was usually a flashing MCACC, Phase Control or Power On LED that indicated a fault. Could be a short, overheat, over-current or high DC current detected in the power supply.
I assume it was working OK before the storm so we can probably rule out stray speaker wires touching the chassis causing a short but it wouldn't hurt to double-check before you try the reset.
my SC-57 powered off on its own (all my other electronics and TV stayed on), and started blinking the blue advanced MCACC light. The standby light would then not come on around the power button, and the unit wouldn't power up any more. I unplugged it and plan to try it again tonight when I get home from work.
