Originally Posted by Terrya
I'd keep trying to help but I think I could read your posts for a week and still not understand what you're doing. I really wish I could help but I'm just not getting it.
Good luck figuring it out. If a light goes off in my head I'll post back, but for now I have nothing.
Edit:
Okay, so you ran your LFE output through the Y connector to the external amp using both low level inputs set to stereo, then output through one speaker level wire to the sub, using the bridge terminals, with the sub jumpers attached. Did I get this right? This was the first configuration? Was the sub amp set to auto or on? Did you happen to see any change in the status light on the amp indicating a problem? I guess this should have worked, although I'd prefer no Y connector in this setup. Now that you know the drivers aren't responding to any input I guess you know where to focus your attention.
Edit:
You have described what I did accurately, with the exception that I first had the two voice coils wired in parallel, which would have reduced the impedance to 2 ohms, I believe. I turned the sub amp on, there was a short, low hum which stopped when I turned the sub amp from on to off. The hum stopped, but when I turned it back on again, there was no hum anymore. I suspect I fried the coils at that point. You mentioned having read the sub amp manual. Do you know where I could get or download the manual for the Jamo MPA-100? I will replace the speaker, but want to correctly connect everything. Regardless, I will start by only connecting a single RCA from the SC-55 to the sub amp. Thanks for you comments.
