Originally Posted by jerrydf
The good:
This is the best sounding receiver I have ever owned or experienced. It is a technological powerhouse with every known bell and whistle and then some. The self-calibration offered is very comprehensive contributing to the receivers exceptional musical sound.
The bad:
1. The sat/tv inputs lack an HDMI jack. This unit replaces a 4 year old Onkyo TX-705 and that one had a dedicated HDMI jack for a satellite receiver. To get an HDMI jack I had to use the input4/VIDEO inputs which I renamed TV-SAT. The remote has no button to go right to that input.
The good:
The bad:
No. The Sat/TV input uses the Audio Return Channel of the HDMI Output jack. In fact, if you use the ARC, you can't plug anything into the analog audio Sat/TV inputs at all. (IMO, you should be able to use the input control - the one that switches between the analog and various digital inputs - so you could use both the ARC and the analog in. I spoke to Pioneer about this but they claim that it's not possible and it can't be fixed via a software upgrade.)
I don't know why, but there is one big advantage to it: if the receiver is pulled away, that plug will pop cleanly out of the jack without damaging the receiver, although there are non-screw F plugs that will work on a threaded jack as well. I've had to swing my unit around to adjust the input wiring and that FM antenna cable pops right out. I probably would have had a disaster if it was the screw-type connector with a screw-type plug.
That surprised me also, but what I did the first night I installed it, since I didn't have any singles around, was to saw my paired banana jacks in half. Then I ordered new single ones from Monoprice. Works fine.
Most people feel this receiver sounds great. And it does sound pretty good for movies. But for music listening, in both analog and digital, I don't happen to think it sounds all that great. I don't feel like it has very much definition and it doesn't sound crisp to me. I think my (very) old analog system which was an Apt-Holman preamp, Crown D-75 power amp and Sony STJ-75 tuner actually sounded better and that obviously had no room EQ system. I have to admit to being a bit disappointed. Everyone told me that the Pioneer would blow my old system away. And since I live in a city apartment, I don't have the room to keep both systems up.
