AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › A few questions about my "Home Theater"
post #1 of 13
Since i'm buying my first TV i will bump this thread of mine and ask you for some help. All your suggestions will be greatly appreciated.
1. Budget
I'm willing to spend around 900€ = 1 130$
2. Seating distance
From 9' to 11'.
3. Size/placement limitations
I have no placment limitations. Looking at 46" to 48".
4. Uses and sources
The only device that will be connected to TV is my PC (trough HDMI). I will be using my TV only for watching movies and series. I will not watch sports, won't play games or to be more exact i will not connect my TV with cable TV or inernet TV.
I will mainly be watching HD material (Full Blu-Rays, 1080p encodes). I watch SD material (DVD9 sources) only when series/movies don't exist in HD.
HD - 70%
SD - 30%
5. Room lighting
I would say "almost dark". There is no bias lighting.
6. Important factors:
- Very important to me is 1080p/24 or 24p compatibility!
- Best PQ possiable.
- Preferably i would like to have LCD Full LED (if possible).
- I don't care about 3D so this is an important factor.
- Since i'm from Europe i can't use and don't need "Internet streaming services" like Netflix and Hulu.
- I also don't need services like Pandora, Rhapsody, Picasa, Flickr, access to Facebook, Twitter, and even Skype.
post #2 of 13
I very well could be mistaken here, but I believe VGA maxes out at 720.
post #3 of 13
Displayport is comparable to hdmi so don't confuse it with VGA. However does that HP actually have a DisplayPort? It's not clear to me.
post #4 of 13
@Sonyad: Yes HP has DisplayPort. How much difference is there between HDMI and DisplayPort? Which do you think is better for playing HD material? My HP or Toshiba?
post #5 of 13
Incorrect, VGA is capable of much higher resolutions, up to at least 2048×1536px, VGA is however analog so higher resolutions with inferior long runs of cabling will cause problems. I have a 1080p monitor hooked up to VGA right now and it works fine. Best way for the op to check is try it.
post #6 of 13
I'm completely new to Displayport up until the last few days. We had a Dell Ultracompact computer we wanted to hook up to a tv. The Dell only had a vga port which was missing from the tv, so it couldn't be used. However I wondered what that unidentified port was on the back, and after a bit of sleuthing I discovered we did indeed have a hd connection.
Being green at this, I can't give any recommendation except that hdmi is the more popular standard in consumer electronics. I haven't had to buy a monitor lately, so I don't know how pervasive displayport is with monitors. This link might provide a few answers: http://en.community.dell.com/dell-bl.../19/46464.aspx
post #7 of 13
They're both pretty portable (being laptops) so why not just try both?
post #8 of 13
Because i don't want o waste money for more cables (VGA to HDMI or DisplayPort). This is the main reason why i am asking here for some help so i could avoid unneccesery expenses.
I have read here that both VGA and DisplyPort are inferior to HDMI:
- http://www.edn.com/article/472679-Di...standards_.php
- http://homecinematics.com/167/vga-to-hdmi-converter/
post #9 of 13
HDMI and VGA are comparable for video quality to the untrained eye, HDMI is better for video only slightly. HDMI is so much better in other aspects because it can transport 3D and HD sound. Either setup will work for the OP but I must say HDMI will be easier to use as long as it is set up properly on the computer, if it isn't I wish you luck. VGA will require a separate cable for audio.
post #10 of 13
@malovich: Can DisplayPort also transport HD sound?
post #11 of 13
1. Budget
2. Seating distance
From 9' to 11'.
4. Uses and sources
HD - 70%
SD - 30%
5. Room lighting
post #12 of 13
I have used both HDMI and VGA into my 46" Samsung @1080p. Coming from a Dell inspiron dual core 5000, 512mb xfx video card Did not notice any real difference between the two. Try not to over think it. VGA cables are very cheap (monoprice.com). Grab one and try it.
post #13 of 13
@Hockeypuck25. I asked some new questions - see comment 11.
