AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Recorder with HDMI Inputs? Yes it exists
post #1 of 152
How are you guys well I just in my researchs since I was doing every research concerning the other DVR etc to know the characteristics, which I'm about to get tomorrow, (but the most it can go on a chinese forum is 720x576i).
I have found out that in China there exists the recorder which has HDMI inputs:
Also it has more inputs:
2x HDMI (HD)
1x Component (HD)
1x S-Video (SD)
1x Composite (SD)
I don't know if you already it by know but if not get ready to be blown by the recorder but also by the price 500 dollars not counting with the import which might cost a lot more the version before 3700D although it«s called a recorder but it doesn't have inputs at all!
Check out the comparison:
http://www.magictv.com/hk/en/mtv7000d.html
HDCP is not even mentioned anywhere maybe because it's uh ... China or in this case Hong Kong
post #2 of 152
Sounds interesting, depends on availability and pricing. But unless its "fully compliant" (i.e. "crippled from actually recording anything") there's no way it could be imported to North America without running afoul at the border. Small packages containing mysterious dongles (like the HDfury adapters) can be ordered by individuals and skip past inspection easily, but a larger box containing an obvious recording device is much more likely to get held up. We'll just have to see.
I'm not particularly thrilled with recorders requiring a web connection to their own Guide service- TiVO may have pulled this off, but its been a mess for everyone else who tried it. This recorder also misses the mark in terms of the ridiculously unrealistic expectations Americans have: they want a cheap unit costing under $300 that REPLACES their cable box so they can avoid the monthly fee. This one appears designed to work WITH a cable decoder as an advanced accessory, a nice idea for those who can appreciate it but not the typical consumer. Cable integration is the Holy Grail of American recorders: no one has managed it effectively except TiVO, where it comes at a stiff price and still requires cooperation/hardware from the cable service. Then of course we have the huge penetration of competing satellite services which aren't compatible with anything.
While this MagicTV 7000D would probably not cut it as a mass market item in US/Canada, it would be great to have available as an alternative machine for those willing and able to understand its features. Hope it manages to get here in some form, even if we have to buy a "Now" TV to go with it.
post #3 of 152
im trying to find a blu ray recorder with component inputs.
post #4 of 152
According to the web site you posted, the MTV7000D costs $3980 MSRP. That's a bit more then $500. Even the 3700 says it's $2980, which only has dual tuner lilsted as an input, no video inputs at all. Other than that. it simply looks too good to be true. There is no info on the tuners.
post #5 of 152
I saw some chinese forums commenting that you could record it in 1080p from the HDMI input because people didn't want the Hauppauge also only in China.
Now I saw a blog and wrote to the author of it to get more info but still hasn't responded take a look:
http://www.ordinarygweilo.com/2011/0...-mtv7000d.html
It's a british living in hong kong,
I also saw in my researchs that there exists another one but it doesn't have hdmi inputs and I think it only supports 1080i as component inputs the models are VD-R
here is the website:
http://vdigi.com.hk/productlist.php?cat=5
The model the cheapest must be the 160 GB of course I will call them tomorrow and take a look and tell you what they said to me
post #6 of 152
There exists one model from those which are from the Vdigi that has no disk inside:
http://vdigi.com.hk/productdetail.php?prod=39
Last price I saw online but not said from them was 1500 hong kong dollars so it's almost 200 us dollars remember no disk inside you have to buy it yourself
post #7 of 152
Hong Kong dollars. Current conversion rate is about $510 USD.
I'm going to check with one of my colleagues in Hong Kong.
post #8 of 152
Cool man thanks please let us know about that me I would rather be interested in V DIGI since it has component input capabilities but I still need to know the exact price of the 160GB and the Rwo version (with no disk)
Also I really need to know if it can record up to 1080i through the component inputs, one thing is certain the USB exportation of recorded shows is a whole new level
post #9 of 152
If you are willing to spend $500 on a chinese import, just buy a TiVo.
post #10 of 152
The thing is that I don't think a TiVo let's you record through hdmi iinput or component input.
Also I am not interest about this unit Magic TV 7000D, I was more interested into DVR2008 which is a Philips but then I understood that it could go up to 720x576i with component inputs and the speed of usb exporting things was more like a usb 1 instead of usb 2.0.
While these ones are more faster in terms of usb exporting, I am interested into the V Digi that has a lot of versions but the one which is cheaper might be the VD-Rwo which has no disk.
Tomorrow I'll ask them about the prices and tell you regarding the Magic TV 7000D it is the price you saw 3980 HK$ Hong kong dollars so more like 500-510 US dollars. (Without counting with the importation)
Philips DVR2008 was and is the cheapest solution but has no HDMI output and slower transfers from hdd to usb so I would prefer the VDigi VD-Rwo or VDigi VD-R 160 GB cheapest
post #11 of 152
even if the input is non HDCP dont the outputs on the device u are recording from, have to be non HDCP as well for it to record ?
post #12 of 152
Is there any information on what the tuners are capable of tuning in?
post #13 of 152
Manual in english says this:
1.3 Magic TVHardware Differences
MTV3x00 Receivers (single and dual tuner models)
Compact case
Add external USB Hard Disk Drives (HDDs) to enable full Magic TV
recording ability
Single tuner allows recording of 2 channels (USB HDD required) and
you can watch a third providing all 3 channels are broadcast on the
same UHF frequency (see table opposite)
Dual tuners allow recording of 2 channels (USB HDD required) on 2
different UHF frequencies and you can watch a third providing it is
also broadcast on one of those same frequencies (see table opposite)
Sigma Designs SMP8655 processor
HDMI 1.3 output
MTV3x00 Recorders (single and dual tuner models)
As MTV3x00 Receivers but adds:
Compact metal case
Internal Hard Disk Drive for extra convenience
MTV7000D Recorder
As MTV3x00 Recorders but adds:
Full size metal case
Front panel buttons
High Definition HDMI and analogue video inputs for recording
external sources (e.g. Now TV and Cable TV)
Channels on same frequencies
(Applies to Hong Kong only. Correct as of 18th June 2010)
UHF frequency#1 CH11, CH16, CH81, CH84
UHF frequency#2 CH82, CH83, CH85
UHF frequency#3 CH12, CH13, CH14, CH15
For example, single tuner models can record channel 82 and 83
simultaneously, and then you can also watch channel 85 at the
same time.
With dual tuner models you could record channel 11 and channel
82 simultaneously, and watch any of 16, 81, 84, 83 and 85 at the
same time.
PAGE 9
Link to pdf file
http://www.magictv.com/hk/downloads/...0Guide_eng.pdf
post #14 of 152
Isn't the idea of a recorder with HDMI input to enable HD recording, or at least record HD channels onto a DVD? I'd bet that it would be impossible to record HD content using HDMI from any satellite or cable source. That's why my HD DVR has an option to record out only via composite, which sadly defaults to 4:3. The suppliers do not want us to record their 16:9 content.
post #15 of 152
You prob. need a Component- or HDMI-Composite converter as listed here.
(Same answer to your other question in other thread?)
post #16 of 152
The intent of my question was, Is that tuner capable of receiving over the air channels in the United States using an antenna?
post #17 of 152
Page 22 of the User Manual shows a picture of an aerial antenna connected to the device with a coax cable that is connected to the Ant-In connection on the back. I would say "Yes" to your question based on the manual.
post #18 of 152
Or maybe just Hong Kong channels since it is not made for sale in the USA?
post #19 of 152
In the USA ATSC tuners are necessary to receive broadcast sub-channels:
http://en.wikipedia.org/wiki/ATSC_(standards)
Products designed for use in other regions of the world use different television standards:
http://en.wikipedia.org/wiki/List_of...nts_by_country
One would have to mount an antenna pretty high up to receive line of sight digital TV signals from Hong Kong.
post #20 of 152
Ahh yes...Hong Kong. Isn't an aerial antenna high enough to get reception from Hong Kong called satellite?
post #21 of 152
Thank you. I'm glad the real point of my question was not lost on everyone. I am guessing that the tuner, as has been suggested here, is for Hong Kong stations, and in the U. S. will be as useless as the one in my EH59. (The EH59 manual also has a page which shows an aerial antenna connected to the recorder with a coax cable that is connected to the Ant-In connection on the back. That doesn't mean it will work here in North America, because it does NOT work here.)
Given this realization, that would mean the 3700, which only has dual tuner lilsted as an input, no video inputs at all, would be totally useless here.
post #22 of 152
The first thing I learned working in foreign countries an even here in the States
There is NO STANDARD and that's the problem with Electronics in General among other things .
Didn't mean to butt in ; Doc ...
post #23 of 152
Maybe Funai should begin to think of upgrading its products...
Until then, I'm seriously thinking to import one of these before it will be barely legal just to have an electronic device with HDMI inputs, even a HTPC.
Sorry, FCC.
post #24 of 152
Very pretty. I like the bright colors on the back panel and the remote. Wonder if they're lead-paint. Better not touch food or your eyes after changing channel.
post #25 of 152
..Better not touch food or your eyes after changing channel.
Killjoy.
post #26 of 152
Looks intelesting.
post #27 of 152
Pixel Magic now sells a new model with 1TB HDD.
Thanks for nothing FCC .
post #28 of 152
Forums in English for New Zealand and Australian users here:
http://www.geekzone.co.nz/forums.asp
Seems to be a lot of people using them in those countries...
post #29 of 152
Here's an Aussie board with more information about the MTV-7000D:
http://forums.whirlpool.net.au/archive/1813180
Worth reading it.
post #30 of 152
This looks very good. I have had a little experience with some chinese brand devices and they always seem to give you a lot of features for you money. They usually give you all things you would want to have on known household brand device.
The conneCtivity on this is awesome. I know not many use composite and S-video connections these days but its just nice to have those if ever you need to connect to some old school gear. Now if I can record to the hard drive via RCA’s and HDMI and transfer both ways via USB I would be pretty happy. Now the big question, will the tuner work with Australian DVB-T? I think it might, if not, its probably not a big deal as I already have a HD Freeview set top box for free to air channels. Not real sure what they IR receiver shown with the blue leads is all about. It even runs on 12v DC.
Very tempting but I wonder what other competing products there are?
  Back to Forum: DVD Recorders (Standard Def)
