AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Recorder with HDMI Inputs? Yes it exists
Recorder with HDMI Inputs? Yes it exists - Page 6
post #151 of 167
Originally Posted by hifiphones View Post
...As I understood the MTV7000 would be a better solution as it has less limitations on HDMI recordings?
The standard MTV7000 model is no longer manufactured and it was replaced with Mini model. The only difference between two is lack of component inputs in mini which does not matter if you plan to use two hdmi inputs. Everything else is the same including features as well as limitations. I use my mini's for several months now and they do perform excellent so far. Good luck.
post #152 of 167
Originally Posted by Cyclone82
Interesting thing i found out today when i asked a ebay seller if he had any 'ViewHD' HDMI to component converters. Yes he still has them but will only sell via email and will not list them on ebay. They have also disapeared from Amazon. Seems like hes been told to remove them. These units are the same sort of thing as the HDfury. They must be really cracking down on anything that accepts a HDMI signal and ignores the copy protection.
So, you're saying the View-HD supply has dried up ? Good thing I got mine before they got scarce. I mentioned this in another thread, but some early reports were indicating that this little box
http://forum.videohelp.com/threads/334145-HDCP-strippers?p=2217543&viewfull=1#post2217543
worked and could be a game-changer . . . at least until they try to squelch it also. But my hope is that whatever Big Content tries to suppress, their efforts will amount to no better than a game of whack-a-mole, because other options will keep emerging.
post #153 of 167
Got my MTV7000-Mini, awesome thing!
The only problem so far is that I cannot rename the sources?
I can rename Input 3 which is composite, but Input 1 and 2 which are HDMI cannot be renamed? Any ideas?
post #154 of 167
Weird. Mine allows assigning name to each input including custom name.
It is available in Setup menu under this option
post #155 of 167
Cheers, did mine also under setup but cannot select input 1 and 2. Do you have the newest firmware?
post #156 of 167
Allright, after updating my firmware from 7.02 to 7.05 i found out that there was an input selected under nowTV and cableTV. After changing the input to "none" I was able to change the name smile.gif
post #157 of 167
Congratulations! Do you buy it in the US?
Edited by profhat - 7/1/13 at 11:44am
post #158 of 167
No, got it from HK
post #159 of 167
No, got it from HK
What I am interested in is exactly HOW you got it from HK, or more specifically, how we can get one?
post #160 of 167
I got a mate in HK, who went into a local shop and bought it for me, then shipped to Europe.
One thing I have noticed is, when I am playing a recording a small "PLAY" sign appears on the LEFT top corner. Is this normal, or can be disabled somehow? Quite annoying when this sign appears every 1minute.
post #161 of 167
I had a feeling your source was something like that. Not really a general source for the public, is it. Thanks for the information though.
post #162 of 167
Hi guys, do you think that the new Google's CHROMECAST HDMI device will work with the MTV-7000 line?
post #163 of 167
It can be turned off in Settings menu. Read manual or just browse on your device, you will find it.
post #164 of 167
Hi,
There is a newcomer in the HDMI recording field, check this indiegogo project: http://igg.me/at/wizarm/
Or video link here: http://www.youtube.com/watch?v=tcLuppUAkr4
Looks great !
post #165 of 167
Originally Posted by TheFreeman View Post
Hi,
Looks great !
Please stop spamming the threads with this.
If I see it one more time I'm going to report it.
post #166 of 167
Kelson,  I saw your comment about the Wizarm device.  I wasn't able to figure your thoughts about it, except that you might not care for it.  Is it real or a sham?  Does it work as advertised?  Can you provide some skinny on the device?
CR
post #167 of 167
How many tuners does that Wizarm device have? Doesn't say on the webpage. Do you have to use a PC with it or is it stand-alone like a DVR?
  Back to Forum: DVD Recorders (Standard Def)
