I have a 34" HDTV CRT and a 55" Plasma. For the plasma I have a CM-7000PAL, which works for me. The 34" HDTV CRT does not have a tuner build in. I don't need a DVR or even VCR capability for that TV. The TV has DVI and component inputs, but not HDMI. This will be used in a spare room. Do not need QAM.
I really would like a STB that has good HD PQ for most. Having a nice EPG would be nice as well.
My budget is no more than ~$130.
It seems that either the Zenith DTT901 or the CM7001 would be sufficient. Is there anything I should know about either these two that I should know (they both pass HD signals right?)
Is there some other model I should consider, or hold out for?
I appreciate any advice. I am still new to the OTA world....and so far I am really liking it!
easy to make mistakes.
