Originally Posted by
hifisponge
Understood. Just place them well away from walls and up off the floor on a thin stand, then.
And gate the measurement, to avoid any reflections and their "contributions"...
The best guide to what speaker you will ultimately choose will be the data as well as subjective impression at the listening position. The quasi-anechoic stuff is great to see how it would perform if you were outside with no boundaries (including a floor) and so was the speaker....nice to know how it behaves, but it shouldn't guide your ultimate choice....
Off-axis DR data would be very tasty....if that is consistent with on-axis, it is simply the best bang for buck speaker out there as long as you can EQ them.
I think there is a reason no polars exist for the DR series, though.....but I am secretly hoping that they will be great......as I may have a use for them....
JSS
