AVS › AVS Forum › Audio › Speakers › Speaker Shootout!!
Speaker Shootout!! - Page 2
post #31 of 1131
Originally Posted by cschang View Post
What's your timeframe for getting this comparison completed? Will you have all the speakers at the same time?
I am hoping to keep a set of 3 for all of them. I have at least 3 weeks for the JTR's and eD's and more for the CHT's.
post #32 of 1131
Originally Posted by Gooddoc View Post
Or just buy Omnimic . It's as simple as REW with the rat shack meter, but accurate.
Omnimic does not go below 10hz. I do have the lilmike mic that I want to try out.
post #33 of 1131
Yes, good point. For those of us that don't have to worry about measuring that low , it's a great kit.
post #34 of 1131
but the JBL's midbass and big sound was better. I am hoping to combine both with the DR's.
I keep telling you there is no replacement for displacement in the lower bass regions. Even up to 400Hz I think its very important to have clean, unclipped high SPL potential for the cleanest peaks. Your JBLs had some high quality dual 15" woofers doing that
Subscribed
post #35 of 1131
Originally Posted by hifisponge View Post
MK - If this is true, and you want to do the measurement portion of this shootout properly, you really need a calibrated mic. You can get one for $85 from here: http://www.cross-spectrum.com/measur...behringer.html
Get the "basic plus" model. The "plus" model comes with calibration files for the mic pointed forward and tip-up. I find the tip-up mic orientation gives the most accurate HF measurements.
You'll also need a mic preamp. This M-Audio Mobile Pre is inexpensive and accurate: http://www.amazon.com/M-Audio-Mobile...3125252&sr=8-4
Even with a generic cal file for the Rat Shack SPL meter, there is so much variance between production runs of the meter, that you really don't know what the result is going to be.
Hope that helps, good luck and have fun in your testing!
lmao, we have posted that suggestion about 50 times.
MK, definitely knows what he requires.
post #36 of 1131
I will buy both preamp and mic if that is good enough.
post #37 of 1131
Its double the $$$. Plus, if MK actually bought the mic years ago like many keep telling him. He could have been an expert in using not only REW but great measurement tools like ARTA and HOLM.
post #38 of 1131
Subscribed
The JBL's were the best in the midbass.
post #39 of 1131
Yes, its good enough for many who measure and build speakers. FWIW, I actually thought you did buy them already. I didnt know you still had the RS meter until this discussion.
post #40 of 1131
I have your drivers still in a box so if you want them back......
post #41 of 1131
I will buy today if you guys can tell me which I should. I don't have a problem with doing it, just getting the right one. I have been told so many times that the rat shack meter is good enough it always convinces me to keep using it.
post #42 of 1131
If we can create a DR speaker with a jbl 2225 or 2226 you can call it a day.
post #43 of 1131
The RS meter is fine for bass measurements since we have both seen the comparison threads in the DIY forum on this topic but if you want full range measurements then a better mic is required.
You can buy what hifisponge linked. Its the same setup I own so I believe its good.
post #44 of 1131
lmao, Im still trying to figure out the DR speaker. Other then knowing is a Bill Fitzmaurice creation, correct?
post #45 of 1131
Lets all rejoice!!!!!!! I just bought the premium plus behringer mic and preamp, yeah!!! Now if it measures the same as the RS meter I am hunting you down Penn
post #46 of 1131
lmao, you will just sell me it at a reduced rate
post #47 of 1131
Well, after listening to the DR for a brief time there is so much potential. The sound is very palpable with lots of energy. It is very large sounding and the sensitivity is very high in a sort of compact speaker. OK, out of the box it sounds worse than the M&K's and Triads but the JBL's sound bad too until I tweaked them.
post #48 of 1131
Very much looking forward to the results of this shootout!
post #49 of 1131
It has been used at live events so Im guessing it should be okay for your room
post #50 of 1131
Yeah, but I have used cinema speakers too!!
post #51 of 1131
"Challenge accepted!"
That is not a bad idea. I'll screw around with it when I get free time
post #52 of 1131
Can you guys explain how to EQ properly? I mean which Q to use with a peak.
post #53 of 1131
Agreed. And not as versatile as a preamp and condensor mic. However, it's butt easy to use and is up and running in 20 secs. I know REW is not any kind of torture to setup, but I am not speaker building and for simple FR sweeps, RT60, and such I find myself reaching for the Omnimic.
post #54 of 1131
If you use REW to do it, you can set an overall target, and it will work out the EQ parameters (frequency, bandwidth, gain) for you; and you can manually tweak and get a preview curve of what the expected effect will be. It has settings for various BFDs, but I don't see why those same recommendations that it spits out wouldn't be close for a non BFD parametric EQ.
post #55 of 1131
That would be a huge DR!!
The DR250 uses a 10" and DR280/300 a 12" so a 15" would be huge in one of Bills DR sized cabinets. I was only thinking the biggest I would go would be a 250 because dispersion gets more narrow the bigger you go as far as the DR's.
post #56 of 1131
So what tabs or options do I press to get the target curves? I can copy the settings on my Ada which has 12 bands per 7 channels and 8 bands on the LFE of parametric EQ. When the new speakers come in I want to know which speaker I like out of the 3 here first. I can see why I like the sound of the M&K's and why their vocals are more pronounced, The 900-2K range is much higher and flatter than the others. Once I get the other 2 to play like this it may change everything. Usually I do this stuff fast but with the new baby I have limited time.
post #57 of 1131
I was assuming since you mentioned you calibrated them all to 75, that you ran Audyssey (or equivalent) on them and saved to a preset? Or did you just mean used the RS meter to set the levels to 75?
If you haven't, that would be my first thought, see how close Audyssey can get you for the mains, since its easy / one button approach. Or would Audyssey not have sufficient EQ horsepower to address the FR? I use MCACC, not Audyssey, MCACC only has set frequencies on EQ, not sure if Audyssey's are parametric - if not, guess that may not help.
(sorry, forgot what receiver / processor you're using, not sure if Audyssey applies)
Otherwise, for REW and the separate parametric EQs, then you'd take a measurement, push the EQ button at the top to bring up the EQ panel; drop down "Equalizer", set to "Generic"; drop down "Target Settings", select "Speaker Type = Full Range", adjust crossover settings as needed (how you're crossing them over to the sub); click "Set Target Level"; drop down "Filter Tasks", set the "Match Range" to whatever frequency you want to try to adjust (like 80-12,000 say), set individual boost to somewhere between 0 and 3 dB, overall max boost somewhere between 0 and 6 (YMMV), flatness target 3 dB, then click "Match Response To Target", which sets the filters. Then click the "EQ Filters" button at the top to see what filters it set up - and you can manually add filters and see the predicted effect if you aren't satisfied with what REQ came up with automagically. You can then manually enter those PEQ settings into your PEQ for that channel.
Repeat for each channel.
post #58 of 1131
Neither do any of the RS meters.
Ah, good. About damn time!
post #59 of 1131
Subscribed
post #60 of 1131
Sweet! A recipe I can follow! Can't wait to try it. I had manually set PEQ filters to EQ my sub.
  Back to Forum: Speakers
