Originally Posted by
MKtheater
This is the only alignment I have not tried.
You have done this already twice
zacjones
I'm looking forward to seeing how this turns out for you. I'm getting ready to put in 8 IXL18's IB as well. It'll be nice to see how you think a massive IB stacks up against the other over the top options.
MK does not have enough space for 10x VAS which essentially removes the box limitations from the design. This solution is really a just building a large sealed enclosure (62cuft) and putting 8 drivers in it. The 8 drivers model here the same as they do if he built sealed dual 18" 13cuft boxes.
The performance is not much different then when he had 8 18" eD drivers in sonotubes, its a complete circle back to what he first did. Although the alignment, driver position, driver vibration cancellation in the original design had its advantages.
I guess Im saying that MK has already been here twice. Once with 8x18" eD drivers and then once with 4 CHT 18.2 boxes. The only difference now is that he is choosing drivers with more Xmax (more extension).
