As is customary with NAD, they disclose power output with all channels driven simultaneously, unlike most manufacturers. So you have to mentally "bump up" their figures to compare with a Denon or an Onkyo.
One notable omission I believe is Audyssey technology in the form of MultEQ flavors, Dynamic EQ, or Dynamic Volume -- someone please verify.
Here are some specs:
AMPLIFIER SECTION T 757
TUNER SECTIONFTC 7 x 120W
Full Disclosure Power (all channels driven simultaneously) 7 x 60W (0.05% THD, 20-20kHz)
IHF Dynamic Power 8 ohms
4 ohms
137W
243W
Total Harmonic Distortion at rated power <0.08%
IM distortion at rated power <0.08%
Damping Factor, 8 ohms >60
Input Sensitivity and Impedance 250mV/50kohms
Frequency Response ±0.8dB (ref. 1kHz, 20Hz-20kHz)
Signal/Noise Ratio >100dB (ref. rated power at 8 ohms, A-WTD)
>90dB (ref. 1W at 8ohms, A-WTD)
GENERALAM SECTION
Tuning Range 530kHz - 1710kHz (120V version, 10kHz steps)
531kHz - 1620kHz (230V version, 9kHz steps)
Usable Sensitivity 30dBμV
Signal/Noise Ratio 38dB
Total Harmonic Distortion <3%
Loop Sensitivity 20dB S/N 66dBμV
FM SECTION
Tuning range 87.50MHz - 108.50MHz
Usable Sensitivity Mono <15dBμV
Signal/Noise Ratio Mono
Stereo
60dB
55dB
Total Harmonic Distortion Mono
Stereo
0.25%
0.5%
Channel Separation 40dB
RDS Decode Sensitivity 28dBμV
Idle Power 53W
Standby power <0.5W
Unit Dimension (WxHxD) - Gross **
(includes feet, knobs and terminals)
435 x 172 x 397mm
17 1/8 x 6 13/16 x 15 11/16
Net weight 15.4kg (33.9lb)
Shipping weight 18.0kg (39.6lb)
