Originally Posted by Ozzie Isaac
I am pretty sure the problem is in the bluray player. I updated the firmware last night (i keep all my firmwares updated) and it stopped working with the wall plates. I switched cables again and cycled power on everything and it all started working again. Very annoying. It has prompted me to send it all back and try a different setup. Also, when running a direct 25' cable I never had any issues with the bluray player.
What I meant by "misinformation" is if you are getting a picture then you are getting a perfect picture, but in reality you can pass hdcp and still have bit drop out. Reputable dealers are the best way to avoid problems. I stick with monoprice, or amazon basics.
I think I understand your misconception. You don't "pass" HDCP and then go on watching video without HDCP. HDCP is with you with every transmission, at least video and audio transmission. Each bit of that data is encoded. You do pass keys but the keys are also reset regularly.
So, if you get drop-outs that is a clear sign of a bit error, which includes HDCP encoded video data. What we usually tell people is to watch for 5-10 minutes. If you see no sparkles or lines or black screens or screens of a single color, then you're good with that source and that sink.
The advantage of a certified high speed cable, is you shouldn't have to worry about any of this. A reputable dealer will be able to provide the certification for the high speed cable.
BTW, I have known a few wall plates to cause problems with high speed signals.
