I just purchased Sanus speaker stands and they are flat, with no mounting bracket or anything. They came with little adhesive triangles for each of the four corners, but I'm not confident that they will keep the speaker secure.
What are some suggestions? I've heard blue-tack works well, not sure where to buy it other than amazon, of course.
Also, I thought about using velcro strips to secure it to the stand.
And looking at home depot, I saw these: http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Would those maybe work better?
Which is the best of these three suggestions, and if there are, any better ones?
Also, will I lose any sound quality using an adhesive to secure the speaker to the stand?
Thanks, guys.
Thanks, guys.
