WOW! that was some fast shipping! Way to go parts express! Looks like I dont have near as much time as I thought to get the cabinets ready! Here are some tasty pics
this is obviously for four cabs, if someone is interested in a cutsheet for two, after I get these guys built and measured, let me know and ill put one together for you.
Are you using stock Eminence crossovers? I'd be interested in seeing measurements if you have the ability. Assuming the xover's do a good job, this could be a nice budget setup.
I would use the Selenium D220ti over the APT-50 compression driver. It's $40 more for the pair but probably worth it if within budget. Plus, there is already a crossover designed for the Eminence 10" coaxial & D220ti combo that would probably work well with the 8" coaxial as well.
Ahh.. not a bad idea. Are the threads the same size for the Selenium? Could it be used in the coaxial configuration or would one have to use a horn with it too? Part of the appeal was the compactness of it being coax and not 'needing' a horn.
Got a link to that particular crossover, CZ? That would be helpful.
Yep, I will definitely run some sweeps with a pair in stereo once they are all done. hopefully this week sometime.
these are the 10" coaxials that I have. I would be willing to go ahead and order a pair of the seleniums and the other crossovers if you provide the link and as stated below, they are threaded properly? if the seleniums and their respective crossovers are able to drop the xover point to 2000hz then I really think they will do a better job matching up with the FR of the midrange driver...
It was Zilch who did the 220i/Coax XO for a guy doing some type of art show and they tried both the APT and 220i, Here's the thread and there's a LOT of good info in it.
In the end, while the builder/user was happy, the designer wasn't overly 'thrilled' with the performance for music BUT for surround duty, i think it's and EXCELLENT option. Good luck with the design and if done properly could be staple for matching to high efficiency mains in a X.1 system. I would think that a slanted baffle, high wall ceiling mount would be a good option. The eminence coax driver isn't nearly as efficient as the CD and will need as much help in the LF department without loosing efficiency to BSC so proper integration/mounting is key. Now it's also important to remember what 'plagues' the performance of a coax is the mating of the CD to the waveguide that in this case is the cone itself. In order to achieve bass extension, the cone is going to have to move air and the more the cone moves, the worse the diffraction artifacts from the CD to the cone. Damned if you do and Damned if you don't so be mindfull of how much bass you expect outta these. Might be best to even add a midbass/subwoofer somewhere to relieve the Coax's of sub 100hz content all together.
with the selenium it would mesh well with your crites. If the 220 is able to operate down to 1.2khz, it would definitely increase the value of building these surrounds as the APT and xover only rolls down to 3.5khz. I feel the mid will be better suited with a lower xover point.
Originally Posted by tuxedocivic /forum/post/20818187
can you run them not in stereo away from all boundaries and gated? That would offer a better idea of FR.
ill run them GP if im able to work out the logistics, im pretty sure I can accomplish it with a few extension cords but i would still be concerned with the noise issue as I have an interstate too close by to get a decent low level noise floor.
while sub 100hz content would be great to get out of these, my main concern pertaining to the design is to match well with any compression driver'd mains. Seems the market is a little thin for something like this in a small "surround" form on a budget level. I wouldnt dream of making these work for musical presentations but the whole cab built at a sensitivity over 100db's is what appeals to me.
Id love to figure out a good (better) way to mate the CD to the driver so that as excursion of the woofer increases, there is a better way to quell the diffraction. not sure how i would accomplish this without separating the compenents but ill put my mind to it. Just thinking, if you had a decent distance between the CD and the woofer to allow a stagnant surface, the performance would likely only be detrimental at the outskirts of the CD's usable dispersion. wow, i just blacked out from all that technical talk!
back to the point, even at 100hz up, these with a slanted baffle should build their own nitch for many of the folks with high efficiency mains.
Well...i hope i'm not spoiling your party but the HIGHEST efficiency you can hope for with these is 90-91db as the raw coax woofer is 93.5 db and you're gonna need 2-3db or half step BSC for the rising response from 100-800hz. That doesn't mean they aren't a good choic, just not a super efficient choice.
Might be best if U and I stayed outta any coax threads. Remember what happened last time?
Man.....that thread neared epic status. Sorta Ali vs Frazier...........
I've grown up.....or mellowed out a bit since then though.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
