AVS › AVS Forum › Home Entertainment & Theater Builder › Outdoor Theaters › outdoor TV hanging
outdoor TV hanging
post #1 of 3
I've recently had an outdoor fireplace built. I would like to hang my new 46 inch LED in front of the fireplace. This will be a temporary mount that I will put up and take down when I watch TV out there. I bought a basic mount for the TV from monopric to place on the back of the TV. I have a pergola above that I would like to hang from. Can anyone think of a method to do this?
post #2 of 3
the way its described its like you're trying to hang the tv from the pergola? and not attached to the fireplace at all? a picture or two of the area in question should help us help you
post #3 of 3
I'd think you can find some eyebolts with the same thread pattern. Shorten the bolt if you have to, and hang it with ss cable or "go poor man" and use chain? It will probably hang with a slight angle though. It will also sway in the breeze too im sure.
  Back to Forum: Outdoor Theaters
