Thanks here is exactly what it says when i pull up the service menu.
******Page ( 1/1 )******
Current Time: 4245 HOURS
Usage Time Code Status
00000 HRS 0012 Happened
So i wanna say current time is how many hours it has been up and running. I don't know what code 12 means. says and usage at 00000 makes no sense to me. neither does a status of happened.
I also notice it says i can erase log by pressing cancel so i hope the store did not erase the log at some point. Thats all the info i get. there is no other page or things i can select.
I will finish calibrating my tv today and test more movies. I do use a media center pc with with a blu-ray player so most of my content is compressed mkv content. Which worries me in that the brightness or deep blacks could be an issue with the source content not the tv.
Also amy recommendations on what movies to calibrate with or test with amazing colors? seems most of my movies are really dark.
Also i have an ATI video card and was playing with the color settings in the control panel. I tried their bright preset which brightned up the picture just a tiny bit. I thought it helped. I was watching V for Vendetta which is very dark seeing if it helped see the detail in blacks. Do you guys recommend tweaking the video card along with the TV settings to get an even better picture or is that not recommended?
So if the Tv has only been used for 4000 hours which seems to equate to less than a year of use. You don't think it would show signs of wear like low light output would you?
Thanks for the help guys.
The concern I have, and it is strange one, is about my 18 month old daughters life. We live near a fault line in California and was wondering how one could earthquake proof this TV so that in the event of a quake that it wouldn't fall on her and kill her. Any thoughts or suggestions on if that would be possible? Are there hooks at the back that could be connected to mounts in the wall or some other way to brace/support the TV (I know that wall-mounting isn't possible)?
