I have a question about the best general recommendation for 3D display settings. At the top of this thread there are display setting recommendations for normal 2D viewing, but none for 3D.
My screen is a 110" 16:9 DaLite Cinema Vision at 15'3" throw distance. Projector temporarily mounted near dead center of the screen.
Here is what I'm using for 2D:
CINEMA1
Contrast 90
Brightness 53
color temp Low 1 (6500k)
Sharpness 10
Film mode Auto1
Color space Normal
Gamma OFF
Code:
MODE: LAMP: LUX: LUMENS: EST LUM/CLOSEST:
CINEMA1 LOW 181 603 711
CINEMA1 HI 289 963 1136
DYNAMIC (mostly unchanged from OOTB and only used for 3D viewing)
Contrast 89
Brightness 55
color temp High (8500k) - OOTB
Sharpness 7
Film mode Auto2 - OOTB
Color space Wide3 - OOTB
Gamma 6 - OOTB
Code:
DYNAMIC LOW 217 723 853
DYNAMIC HI 347 1157 1364
DYNAMIC 3D HI 323 1077 1270
For
Dynamic mode, there are many settings still set from OOTB to maximum - Contrast, Color Temp, Color Space, Gamma 6. As you can see above, the brightness difference between my Cinema1 and this mostly default Dynamic are substantial. This is expected with the High (8500k) color temp. While I have tuned Contrast, Brightness and Sharpness, what should the 4 other settings be set to in the Dynamic mode
for 3D viewing?
Then since there is no DI active in 3D, I assume any calibration intended for 3D should be setup using DI = Off. Correct?
Also, is there a good english cookbook/guide for calibrating the Sony's that use a similar menu format as the HW30? (Cine4home has some german videos, but those are obviously not going to help english users). This is just about the only source with suggestions that I could find:
http://www.projectorreviews.com/sony...alibration.php, but it doesn't walk through calibrating gamma or RCP and they seem reluctant to use Gamma=Off for any mode. Of course, this was for a HW15 and not the newer HW or VW models.
PS: the "EST LUM/CLOSEST" is based on the lux to lumens calculator spreadsheet's estimate of lumens with the projector at the closest throw distance. In my case that would be somewhere near 11' 2.5".
