Originally Posted by
jmalto
Stereoscopic needs to be enabled and it should be if you are using 3DTV and it is functioning. Once you hook up the projector it should detect an HDMI 1.4 device and show you those settings.
For the settings, for 1080p you can output at 24hz and for 720p you can do 120hz. Mine autodetects and I don't have to mess with this.
Use the nvidia stereoscopic player, I never could get Theater 5 to work with anything well. The other alternative is the new PowerDVD.
Also, for the Sony I had to disable my laptop's lcd in order to get 3D to work. Go under multiple displays and disable your LCD and just keep the Sony checked.
Followed your instructions (for there most part) but for some reason sine I update the software/driver the Stereoscopic menu is no longer available. A couple of storage anomalies I noticed and here is a copy of my Nvidia system iso (if it means anything).
NVIDIA System Information report created on: 08/11/2011 18:06:03
System name: HTPC
[Display]
Operating System: Windows 7 Ultimate, 64-bit (Service Pack 1)
DirectX version: 11.0
GPU processor: GeForce GT 520
Driver version: 275.33
DirectX support: 11
CUDA Cores: 48
Core clock: 810 MHz
Shader clock: 1620 MHz
Memory clock: 600 MHz (1200 MHz data rate)
Memory interface: 64-bit
Total available graphics memory: 2815 MB
Dedicated video memory: 1024 MB DDR3
System video memory: 0 MB
Shared system memory: 1791 MB
Video BIOS version: 75.19.1B.00.01
IRQ: 16
Bus: PCI Express x16
[Components]
easyUpdatusAPIU64.DLL 1.3.5.0 NVIDIA Update Components
WLMerger.exe 1.3.5.0 NVIDIA Update Components
Nvlhr.exe 1.3.5.0 NVIDIA Update Components
daemonu.exe 1.3.5.0 NVIDIA Update Components
ComUpdatusPS.dll 1.3.5.0 NVIDIA Update Components
ComUpdatus.exe 1.3.5.0 NVIDIA Update Components
NvUpdtr.dll 1.3.5.0 NVIDIA Update Components
NvUpdt.dll 1.3.5.0 NVIDIA Update Components
nvui.dll 7.17.12.7533 NVIDIA User Experience Driver Component
nvxdsync.exe 8.17.12.7533 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.12.7533 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.12.7533 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.12.7533 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.12.7533 NVIDIA User Experience Driver Component
nvCplUIR.dll 3.7.730.01 NVIDIA Control Panel
nvCplUI.exe 3.7.730.01 NVIDIA Control Panel
nvWSSR.dll 6.14.12.7533 NVIDIA Workstation Server
nvWSS.dll 6.14.12.7533 NVIDIA Workstation Server
nvViTvSR.dll 6.14.12.7533 NVIDIA Video Server
nvViTvS.dll 6.14.12.7533 NVIDIA Video Server
NVSTVIEW.EXE 7.17.12.6742 NVIDIA GeForce 3D Vision
NVSTTEST.EXE 7.17.12.6742 NVIDIA 3D Vision Test Application
NVSTRES.DLL 7.17.12.6742 NVIDIA 3D Vision Module (0)
nvDispSR.dll 6.14.12.7533 NVIDIA Display Server
NVMCTRAY.DLL 8.17.12.7533 NVIDIA Media Center Library
nvDispS.dll 6.14.12.7533 NVIDIA Display Server
PhysX 09.10.0514 NVIDIA PhysX
NVCUDA.DLL 8.17.12.7533 NVIDIA CUDA 4.0.1 driver
nvGameSR.dll 6.14.12.7533 NVIDIA 3D Settings Server
nvGameS.dll 6.14.12.7533 NVIDIA 3D Settings Server
When I play a 2D move in TMT5 you can't select 3D (always been this way). When I play a 3D move it says it's in 3D but it's just like 2D on the projector (projector set to Auto 3D). I now the projector glasses are working because I can use simulated 3D. Also when I have a 3D movie playing the projector goes out of power saving and you can't select it. I'm actually pretty bummed because my focus problem is really bad (makes it unwatchable) and can't get 3D to work to boot.
Center of screen sharp but sides or will look at the 2ed pic.
