A world of difference. Wait for the projector or atleast use a white wall to test.
post #1141 of 5238
9/19/11 at 8:03am
I don't know how much of a difference using my concrete gray wall makes vs. using a projector screen but I had the following experience with Crysis 2 in 3d. I popped the disc in and when I got to the screen where I am told to adjust the brightness until I see the picture on the left, no matter how high I turned my brightness both in game and on the projector, no image was showing up...
How much of a difference not having my screen makes? Do you think picture appears dark because of this? Thanks. |
Grey walls will usually reduce brightness by 20% or more. Have you tried a white sheet? Your adjusting brightness issue doesn't sound right, though. When you increase brightness without adjusting contrast you get a very washed-out appearance from my experience with DLPs, so try adjusting both. Did you try a normal DVD or Blu-ray? Something doesn't sound right. You should get an okay 2D picture out of the box with a normal hdmi input from any dlp. I don't have an HD33 yet, so it could be a projector issue, but I'm guessing it's something else in your hookup.
Hi!
The picture quality itself is very good in both 2D and 3D. For example, Wipeout HD in 3D is very very nice. It is a fast pace racing game and I don't see any ghosting at all in 3D using these "Optoma BG-ZD101 DLP Link 3D Glasses". I had 4 of my buddies over last night and nobody comlpained about ghosting. However, my problem is about how dark the images seem... It is hard to explain because it's not just the black levels but overal colors seem very dark if that makes sense... This could be because I don't have a white background yet. Also, I did notice some FPS issues playing FIFA 2010, but none on other games so far. FPS drop is pretty noticebla when it happens. I don't know maybe I have a defective product... Another thing I noticed is sometimes the screen will flicker like it's re-adjusting or something. It does this rarely but when it does, it looks like searching for HDMI signal. So I am thinking my HDMI cable may be defective. |
so I will be waiting for my supplier to come through
