Originally Posted by xzener
I need help troubleshooting my setup for 3D playback. I have a 3D capable HTPC using TMT5 for playing ISO rips. That is hooked up to a 3D capable Onkyo receiver, which is then hooked up to my HD33.
When I play a movie, it looks odd (as though its displaying 3D), the 3D icon is usable in TMT5 and I can toggle 3D on/off. The projector does not automatically switch to 3D mode (frame sequential is greyed out in HD33 menu). After syncing my glasses... Everything looks odd, both top/bottom and SBS settings.
Putting the physical disk in the PS3... It states it doesnt detect a 3D capable display.
Do I need to buys HDMI 1.4 cables between all of my devices??
I would check the fourms on the Onkyo and make shure it doesn,t need a firmware update to pass 3D (some say they are 3D capable but aren,t that way out of the box). Don't know what video card you have but took me a month to get my HTPC to play 3D blu ray with PowerDVD ( never could get TMT5 to run). Check for the correct drivers 3D setup of video card and some other PC drivers could be causing the problem. As for the PS3 its a different animal then any other 3D blu ray player it can be odd when detecting the 3D display. Connect it to the HD33 directly do the Video setup and then connect it to the receiver and don't do the video setup again and it should remember its a 3D display.
