The Room Mclaren - Page 2
post #31 of 63
Great thread - will be interested in how the journey goes. Love the kitchen redo!
Great job!
post #32 of 63
If you want to maximize the soundproofedness of the room you would put a door on each side creating an airlock effect.
Ah yes,I'll definitely try to work that in. Thanks!
post #33 of 63
Your renderings look great... I can't wait to see the build updates and the finished theater. You might want to look at using something like 3M DI-NOC "carbon fiber" film in your theater. It looks great, is fairly easy to apply, and would really add to the race theme. If you really want a cool display piece for your theater check out www.amalgamcollection.com for some 1/8 scale McLaren's and full scale replica steering wheels. They're impressive, but somewhat expensive. A full scale replica Button or Hamilton helmet from Ebay would be really cool too.
Also, it's McLaren with a capital "L". You wouldn't want to spend a lot for custom printing and have a typo.
post #34 of 63
Great job!
Thanks, I still stand stare at it every now and then!
Originally Posted by FOH View Post
btw, here are the accurate numbers for the Behringer EP4K;
Thanks, I was looking for that info.
Yes, I make that mistake all the time. Carbon fiber, can't be a race theme without it!
post #35 of 63
So the last month has been crazy. Middle of October, the VP shows up at the office unexpectedly, and proceeds to inform everyone that because of the recession, blah blah blah, this regional office is being closed, effective immediately, so basically, pack my stuff, turn in my phone and get out. Wow, that was unexpected. Even more unexpected is that the manager who ran the office into the ground gets promoted to VP of another region, go figure that shite out.
So anyway, theater goes on hold and I start job hunting. 2 weeks later, I find a higher paying job, with just a bit longer commute. Turns out being laid off was the best thing to happen! I was pissed off, but not too worried, since I was given a decent severence package, which will now be used on the theater, ha!
I cleaned things up and worked on the electrical, I had to run 2 circuits to the HT. 1 for the rack and another so I could separate the lights from the wall outlets. Also replaced the metal ductwork with insulated flex duct. A little tricky since I had to build a transition from an 8" x 9.25" square duct to an 8" round T and then branch off 4, 6" ducts to supply the room above. I've decided not to tie the HT into the main HVAC, but to exhaust air into the basement storage room and supply fresh air from the main finished area of the basement. I have to cut a 6.25" hole through the concrete wall, so I'm mulling over where's the best place to do it and which fan/thermostat to get. Any suggestions here would be appreciated.
Also got the soffit built and started quantifying how much material, whisper clips, drywall etc I'll need. Looking at about $2500 to $3000. GAK!! Even doing it myself gives me sticker shock. I've been a construction manager for 15 years and I know what kind of markups contractors put in their bids. I just can't fathom paying someone else to do it, except for drywall, that gets subbed out!
front wall
back wall
entry, planning double doors.
rack area
post #36 of 63
Nice all the way around. Lol I went from that sux to WTF?! To oh cool that turned out well for you and then to great job.
Says alot when even construction people say they will sub out for the drywalling lol. I think I will take heed when the time comes.
post #37 of 63
Thanks 40. You can do it yourself, but, drywalling is such dusty, back breaking work, I'd rather sub it out.
post #38 of 63
Having just (only marginally) dealt with numerous supply lines running across the ceiling of my room I can certainly say that it's been quite a challenge. I think the thing to keep in mind is that no matter what you do, you have a hole through your upstairs floor to deal with where the vent comes through, so the celing joist space no longer becomes a sealed area.
I eventually did a single layer of 5/8 drywall, decoupled from the joists. I built backer boxes for the lights, but didn't go through the effort of dead-venting each vent hole that supplies air to my room. Instead I just put a few layers of drywall just above the openning, which should help reflect some sound back down to be absorbed before hitting the upstairs floor.
For the upstairs supply lines, I wrapped them in Safe 'n Sound insulation so that any sound getting into the vent has to first go through a full layer of that. Given that I'm still left with the gaping whole to deal with, I felt that was in line with the overall effectiveness of what I was targetting. My concept was to bring the whole construction to a certain acceptable level, and try not to go overboard on some areas while negating other weak-links that would leave me no further ahead.
The result? When I get my equipment set up (painting now) I have enough wiring in the room and the house that I'll actually be able to run ETF to show what it sounds like in my living room directly above. It went from "I can hear every word of your conversation downstairs" to conversations being inaudible. Music played fairly loudly though, can still be heard. The sound of the furnance will mostly drown it out, but if it's quiet and you listen (esspecially near a vent) you can certainly hear it faintly. I would say that for me watching at "reasonable" volumes, the sound going into the living will be persceptible but not distracting. Watching at "I'm showing off my system" levels, it'll definitely be heard upstairs for me.
All of that is just to give you a feel what you might be in for. The DD/GG will help for sure but I think to get maximal isolation and near-silence upstairs, you need to consider basically dead-venting each of your upstairs registers. I did a large dead-vent for a CA return in the rear of my room (the rear wall being much more of an isolation priority for me), and it works absolutely wonderfully.
My last bit of advice is be prepared for a very, very, long construction "delay" as you do all of the dead-venting, backer boxes, etc. It's amazing how many isolation issues and weak-links pop up once you start wrapping your head around it. Another one for me was the joist space above my room walls being open to the rest of the house as well; again, you're left with only 1 surface to block the sound and it's no longer a sealed container concept. I bet over half the man-hours into my room was dealing with isolation, and you can see that I went half-assed on a few aspects of it. I could probably have built a normal room for about 60% of the cost...
P.S. Great idea building the right side soffit to match; I did the same thing and I'm very pleased with how it turned out. Turns a liability into something that looks like an intentional feature.
P.P.S. One last thought... It looks like your riser depth is planned at 4'6" with a 2' aisle, which is also what I'm planning for aisle depth. You have recliners in your diagram though and I think you may find that 2' of aisle is insufficient for a recliner. This thread details how a 5'6" riser was re-built at 7' depth because he felt that he needed more aisle space for the recliners. http://www.avsforum.com/avs-vb/showthread.php?t=1103345 If you're not doing recliners in the rear then I think you're set at the 2' spacing.
post #39 of 63
Nice run-down. THe other issue is the mass of the double drywall. If serious bass isolation is a big deal, a third sheet of drywall is an option. Ugh...
post #40 of 63
^^ Take head of everything Ted says; definitely a wealth of great information. I think the hardest thing I struggled with is where that line between reasonable and unreasonable is. For instance, triple-drywalling and then leaving open vents into the room would be a huge mistake. And to go 100% full, all-out, on isolation means levels of complexity, cost, and delay that are disheartenning to say the least.
At various times in the project it's easy to think "I don't want anyone in my family upstairs to hear anything from the room" but then in moments of sanity there's the realization that achieving that simple and lofty goal might be 10 or 20 K in time and expense; in that context, is it worth it? Can 5K in the proper materials and a good plan get you 90% the way there?
Here's another potential weak spot... The concrete floor providing flanking into the rest of your untreated basement and then upstairs from there...
post #41 of 63
Due to the mass, and to some degree that mass' contact with soil, make the concrete a less critical flanking path. Just a small note...
post #42 of 63
Thanks for the input guys!
Well, I'm trying to get things going again, getting equipment and materials. Bought;
swan diva 6.1 mains
Behringer EP2000
18" Mach 5 subwoofer
emotiva xpa 3 amp
5 lane 175 seats
PTAE8000U projector
CyberPower OR500LCDRM1U rack mounted UPS.
Ordered safe and sound today. Next step is to order drywall, channel and run wiring and cables. I had found a mid atlantic rack on craigs list for $50 and thought I would be ok with the glass door, but deciding against keeping the door. I'll take the door off and get some rsh shelves/faceplates. Only thing is, when I remove the door, I'll have to patch where the door hinges attached to the frame. Hope I can find some crinkle paint to match. Got whisper clips, green glue and dispenser, caulk and putty pads from The Sound Proofing Company.
Really impressed with the emotiva/swan combo, even though the speakers are 8 ohm, I am definitely hearing a difference vs just running the speakers with the receiver. They play clean and crisp, no distortion, even when I crank the level up to +10, no hint of stress, whereas with just the receiver I couldn't get past + 22 without hearing some distortion. Really happy. I had 2 diva 4.1's and was planning to get a C3 center, but the center was more than half the cost for a pair of 6.1's on sale, so I'll use one 4.1 for the center and adjust the stage for the height difference and just keep the extra I guess, or sell the 4.1's and get one more 6.1, which I think I would prefer to do.
I would really appreciate suggestions for acoustically transparent screen material, for a DIY screen to match up with the projector. Was looking at center stage XD, but I have no idea. Have to read up on screens I guess.
Edited by ragged - 1/25/13 at 10:07am
post #43 of 63
Glad to see you are getting back at it. Life and finances have to come first.
Center Stage XD is probably your brightest option for an AT material. Some can see the weave if the seating is too close but at your first row distance that should be no problem.
A decent cheap AT choice is spandex. You will need to go with two layers because it is quite translucent. White and Silver Moleskin from Spandex World are what most are using. Putting the silver on top of white helps with stray light and black level but in my experience it sucks the brightness out of the image. I went with white over silver and am quite happy for the money. If my seating was over 10 feet I would probably spend the extra $200 or so for XD just because it is slightly brighter and tends to give a marginally sharper image. The spandex "glows", making object edges a tiny bit fuzzy when viewed close up. XD doesn't do this. (I order a sample of XD for direct comparison.) Search on this forum and you should find lots of good information.
post #44 of 63
Spandex, hmm, never thought of that. Have a sample of XD material coming in the mail, so I'll get some spandex to compare the two. Thanks for the info. Need to read up on CIH. I was thinking of a 110" dia. 16:9, then going wider for the 2.39:1. So, the 16:9 would be 54"x96", then widen the screen width to 54"x129" for the 2.39:1? 129" is too wide though, so I need to make the 16:9 smaller?
Also looking at some carbon fiber fabric to wrap the panels, or at least some trim inside the columns as it's pretty shiny. It's a loose weave, edges unravel when cut, so I have to tape them first.
Edited by ragged - 1/25/13 at 10:05am
post #45 of 63
Quick question guys. Since I have 2 rows, I should split the side surround signal for each row, so I'd have 4 side surrounds speakers. Do I just get a 2 channel amp for the extra set or is there a way to wire the speakers so I can power from the receiver? I have a pioneer vsx 82 tsx receiver. I'm not using the LCR from the receiver since I have an XPA-3, but I don't think I can reassign one of the LCR channels to the side surround.
post #46 of 63
So, after reading around a bit, I think I'll buy an EP2000 and connect both sets to it. At this point the rack is just about full!
post #47 of 63
Hi Ragged - I have a CIH DIY screen that is 54.5" x 130" wide. Like you say it makes about 111" diag in 16:9. We sit on an L shaped sectional turned to face and frame the screen like a V. The apex is 15.5feet from the screen and edges are around 14feet. I can sit in either place and feel immersed in the movie. 16:9 is large but not overly so and makes a great xBox viewing area.
post #48 of 63
Thnks for the info AUrator. I'll probably be about 16-17' seating distance, just because I want to be able to stand up and use the kinect and not block the PJ, which I feel will force the projector closer to the screen resulting in a smaller screen. I'll have to run the numbers. I suppose I could always move the 2 front seats to the side if I need to when using the kinect. What distance is your PJ mounted?
post #49 of 63
Nice job with your room so far. I just finished converting my basement to a Home Theater and wanted to share one of the things I came across. While my intention was not to make the basement soundproof by any means, I used Roxul Safe & Sound in the ceiling between the joists to help knock down the sound to a much lower level for those in the livingroom above. From what I can see from your posts you don't have a staircase to worry about, but in my case I found a majority of the sound escaping through the stairway in the middle of the room and through the basement door.
I would suggest at a minimum to use a solid core door and don't overlook this possible Achilles' Heel with all the great planning and attention to detail you have shown thus far.
post #50 of 63
Thanks for the info man. I'm actually trying to get this sleeping dog moving again, so the safe n sound is something I'm about to order.
post #51 of 63
I know exactly how you feel. We bought our house in 2009 and within a month, ripped out all the paneling, baseboard heat, ceiling tiles...everything. I framed a little but it mostly just sat dormant for almost 3 years, since we were saving & budgeting for this and that and the unexpected. Then this summer I just ordered everything and did it myself in the evenings and on the weekends. Like you, it was tough because we had a 10 month old, so I had to juggle work, being a dad and finishing the project. The whole job took me about three months (20' x 20'), but I finally finished it (I hung the Sheetrock and did the taping/muddying myself which took about 3 weeks since it was my first time doing that (didn't want to rush it and the good ol' learning curve). But now the whole family enjoys the new HT.
I'm looking forward to seeing pictures of the great work you're doing and your final masterpiece. If you have any questions, I'll be happy to share my experiences/knowledge but it seems that you already have a good handle on what your doing.
Best of luck!
post #52 of 63
Well, channel, OSB and drywall being delivered on Wednesday! Time to get to work!
post #53 of 63
Hope you're still happy with the color scheme, no matter how the current F1 season seems to be going.
post #54 of 63
Ha! Yeah, not going so well for McLaren, but the color scheme is still good, I may tweak it a bit, but so far I still like it.
Installed all the clips today and picked up a helpful little tool. Rotating laser level, made installing those whisper clips so much easier. I dug through my garage for all the unused stuff I bought from Lowes, returned them and picked up the level. You should have seen the face on the customer service agent when I plopped down the items, some bought from over a year ago.
Edited by ragged - 5/15/13 at 7:30am
post #55 of 63
I need a little advice on how to go about sound proofing the door. The opening into the theater will be over 20" deep, so I was planing to run the clips on all 3 sides, then screw the door frame though the drywall/OSB into the framing on the outside, (the framing on the left in the picture). So, when entering the theater the door is flush on the outside, but from the theater side, there is a recess. I can't have the door opening inwards, need the space for seating.
post #56 of 63
First of all, it looks like your theater will need a name change for 2015 to McLaren Honda... biggrin.gif
I've never seen clips and channel used to tackle a door recess. Frankly, I don't think it is even a recommended use / application of the clips and channel to be honest. Normally what is done is a "split jamb" where you have two separate pieces of jamb material and preserve an 1/8" to a 1/4" gap between the two pieces. This can then be covered with a molding ON ONE SIDE ONLY to preserve the decoupling. Make sense?
Regarding the swing....so I guess that means that you have to pull the door open, correct? Could you post a wider shot of the theater entrance from both inside and outside the theater?
post #57 of 63
And possibly color change if they go back to classic white&red. Which, if the coca-colasponorship rumour is true, seems quite possible.
post #58 of 63
Haha! Yes I just read about Honda's return today, so we'll see about the colors.
I talked to Ted from the sound proofing company today. He said to anchor the framing for the door to the concrete wall. It wouldn't touch the 2X4 framing for either inside or outside wall so the the vibrations generated by the door would be absorbed by the concrete wall. He did say that having the door flush to the outside isn't ideal, but I need the space, so that takes precedence.
I built 8 boxes to day as well,put up some insulation and as wasted time putting shims behind some clips as the existing framing is not straight along one wall. I literally made one attempt to screw 7/16" OSB together and gave up. Pin nails and wood glue works much better!
post #59 of 63
Got most of the insulation and channel up. Took out the old cans and moved wires for new 4"cans.
Looking towards the screen wall with the equipment rack on the right. I'm sure the rack is going to be almost 150lbs when I'm done, if anyone has ideas how to move it if I need to make a change, I'm all ears. It has wheels, but I was just going to use furniture sliders. Hard to roll 150lbs on carpet with 1.5" wheels.
Looking towards the rear with the entry on the right.
Also built a dragster bed for my 2 yo. Just have to paint it. He loves it!
Edited by ragged - 5/20/13 at 8:06pm
post #60 of 63
Well looks like I have to now figure where to mount that honking Kinect for the new XBOX 1! Watched the reveal and the voice control looks fantastic! Bluray player too.
