AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Integra receiver center channel problem
post #1 of 2
I have a client whose Integra (I think 50.2, but its probably irrelevant) plays the center channel through all the speakers except the center channel. I know this because when I played the speaker level test tones, all of the speakers played the tone correctly, except the center which played through the other 4 speakers.
I'm sure the answer is, "it's a blown amp, call Integra CS for a replacement," but I just wanted to see if anyone had run across this same problem, and if there is something I can look for myself.
Thanks for the input!
post #2 of 2
Let me get this right. You're saying that when you attempt to play the test tone through the center speaker the tone emits from the other four speakers instead?
