Product Description
From the Manufacturer
Yamaha AVENTAGE RX-A810 Yamaha AVENTAGE RX-A810
Featuring unparalleled attention to detail in design, engineering, and fabrication. View larger
Yamaha AVENTAGE Front Panel USB
A USB port on the front panel allows direct connection of your iPod or iPhone
Yamaha AVENTAGE GUI
Full-color GUI with support for album art lets you browse music, movies, and settings
AVENTAGE is a dramatic, inspired leap forward in audio/video component design. AVENTAGE brings studio grade sound and sophisticated video enhancements to your home with unparalleled attention to detail in design, engineering, and fabrication. Yamaha has rethought every electrical path, every part, every piece, and every material to maximize performance. Details that at first glance would not seem to affect the quality of sight, sound, and control, when brought together in an AVENTAGE component, produce a work of visual and acoustic art.
The Yamaha AVENTAGE iPhone App
Use your iPhone or iPod to control the receiver
View App Screens
In addition to an innovative new construction design, the 7.1-channel RX-A810 A/V Receiver offers 3D and Audio Return Channel over 8 in/2 out HDMI, iPhone app compatibility, front panel HDMI and USB digital connections, HD Audio decoding with CINEMA DSP 3D, YPAO Multipoint functionality, Party Mode, and custom installation-friendly features with Zone 2 control.
A Unique Approach to Enhanced Performance
Unparalleled Control: RS-232 for Custom Installation, New GUI, and iPhone App
An RS-232 port lets the RX-A810 integrate easily with any custom home theater installation. Control4 certification means you can make Aventage work seamlessly with your other AV and home electronics products, all from a single remote or control panel, when installed in a custom home theater environment.
The RX-A810 features many ways to control your media. A new full-color GUI (on screen display) with support for album art lets you browse movies, music, and settings on your HDTV. DLNA compatibility delivers network features: Using a local area network (LAN) connection and Windows Media Connect, you can play MP3, WMA and WAV music from your PC or laptop, or listen to any of the thousands of stations available on Internet radio using the included MP3 vTuner data service. Yamaha Network Receivers get you connected to the vast music content available anywhere on your LAN and on the web. You can even control your receiver from any computer in your local area network via a web browser.
The improved GUI lets you control your home entertainment system and adjust settings simply. Its updated, intuitive interface features an HD overlay, so you can call the menu and it will appear unintrusively for quick commands--without interrupting or switching from whatever's playing onscreen.
Need more connection options? The Yamaha AVENTAGE Control App allows for key control functions over your AVENTAGE networked multi-zone receivers. Allowing for instant access to music and other contents you want to enjoy in each of the connected zones. Current functionality includes multi-zone control over the available inputs, volume, mute and power commands by zone. The RX-A810 also has a USB port for connecting your portable audio player or flash drive. It's SIRIUS Satellite Radio ready for even more music (subscription required). Or expand further with optional accessories like the Yamaha YDS-12 Universal Dock for iPod or the Yamaha YBA-10 Bluetooth Wireless Audio Receiver (sold separately).
Enhanced Stability: Double Bottom Construction and a Specially Designed 5th Foot (A.R.T. Wedge)
Yamaha AVENTAGE Fifth Foot
A specially designed fifth foot adds even more stability to reduce vibration
Strong stability in an amplifier design reduces noise and jitter in your digital signal for clearer audio and video. Yamaha's AVENTAGE series of amplifiers achieves maximum stability via a new H-shaped cross-member frame, with cross-members supporting the top, bottom, and sides of the chassis. High-grade, heavier terminals reduce vibration at the speaker connections. An additional bottom cover contributes extra support at higher volume levels for the power transformer and heat sinks. And the specially-designed fifth foot at the center of the amplifier--an Anti-Resonance Technology (A.R.T.) Wedge--improves overall structural rigidity and reduces vibration, resulting in a more stable signal and sound improvement.
Enhanced Power: Optimized Power Amplifier Layout with Ultra Low Jitter Circuitry
The symmetrical power amplifier layout evenly distributes weight across the amplifier to control vibration, improving signal-to-noise ratio for an improved sound experience. The high-quality Burr-Brown DACs feature a direct path to ground, not sharing the ground like in other amplifier designs, for a more efficient and clean signal. Built-in Ultra Low Jitter circuitry reduces jitter from digital sources, including HDMI, using a more precise timing control--so you can be sure of a stable audio/video signal, resulting in perfectly reproduced images and sound.
A hybrid power supply makes the AVENTAGE series even more efficient. Independent power supplies for the digital and analog circuit results in less power consumption in standby mode, and a more efficient power transformer--so despite the power of the RX-A810, it could cost you less to run.
Multizone Capability for Extending Your Home Theater Experience
With support for audio and video in two zones, controllable by the full-color GUI and/or controls on front panel, the RX-A810 can become your home entertainment hub no matter what room it's in. An included Party Mode enhances your next get-together.
How AVENTAGE Delivers Lifelike Sound and Picture Quality
The Latest HDMI Features and High-Definition Audio Decoders for a Cinematic Experience
With seven channels and 700 watts of powerful surround sound (100W x 7 RMS), you can immerse yourself in your favorite movies and music. The latest HD Audio format decoding such as Dolby TrueHD, DTS-HD Master Audio, Dolby Digital Plus, and DTS-HD High Resolution Audio render soundtracks in lifelike detail. The latest HDMI support brings features like Deep Color (30/36 bit), x.v.Color, 24Hz refresh rate capability, and Auto Lip-Sync compensation.
Yamaha Aventage RX-A810
Yamaha AVENTAGE SCENE Buttons
SCENE buttons automatically launch multiple operations to make your devices work together
The RX-A810 features 8 1080p-compatible HDMI inputs (including 1 front) and 2 HDMI outputs (simultaneous), so the RX-A810 has room and power to spare for all your high-definition home entertainment gear. The front HDMI input is great for quick connection of the latest gaming consoles and HD camcorders.
Exclusive Yamaha Features for Surround Realism
Yamaha Surround Realism
Enjoy the effects of CINEMA DSP surround sound without the surround speakers
Yamaha CINEMA DSP is an advanced exclusive technology for creating richly realized independent sound fields that envelop you in an unmatched surround sound experience. With dialogue, music and effects ideally located in these separate sound fields, you will hear sound with accurate placement, smooth movement, exceptional clarity and richness, and startlingly realistic presence. 17 CINEMA DSP 3D settings let you customize the effect for your room. Adaptive DSP Level evaluates the difference between the volume level and a reference level, adjusting the DSP level to ensure optimum effectiveness, so you'll experience cinema-quality audio even at lower volumes.
CINEMA DSP's decoding technology also takes advantage of Yamaha's Compressed Music Enhancer, so you can enjoy your digital music library on your home theater system without sacrificing audio quality. Plus, CINEMA DSP 3D is expandable to 11.2 channels (with front and rear presence speakers) by adding an external amp--so the RX-A810 is a receiver that can grow with you.
Pressing a single SCENE button automatically launches multiple operations to make your devices work together--no more fumbling with the remote control. They are initially set to default settings for DVD Viewing, Disc Listening, TV Viewing and Radio Listening, but can be customized to whatever you need.
Yamaha's YPAO system uses a small microphone (included) and sophisticated equalization to automatically set the best sound for any room, no matter where the speakers are. First, it checks the speaker connections and phase of each speaker. Then it sends out tones which are captured by the microphone to analyze the room acoustics and sets a variety of parameters, such as the speaker size, the distance of the speakers and even the sound pressure level until it achieves the best sound conditions for your room--and you don't have to do anything.
Expand Your Yamaha System with Convenient Connectivity
The optional YDS-12 Universal Dock lets you connect your iPod or iPhone to the receiver. And the YDS-12 is "Works with iPhone"-certified, so you can get the most out of your iPhone music library with zero hassles.
The optional YID-W10 Wireless Dock System for iPod/iPhone ensures that you enjoy maximum sound quality and no lip sync (AV matching) problems.
The optional YBA-10 Bluetooth Wireless Audio Receiver docks to the receiver and supports A2DP stereo audio streaming, so users can enjoy music wirelessly from Bluetooth-enabled smartphones, Windows PCs, and Macs.
Technical Specifications
Impedance: 8 ohms
Frequency Response: 10Hz - 100kHz (3dB)
Total Harmonic Distortion: 0.09%
Signal-to-Noise Ratio: 100dB
USB Inputs/Outputs: 1/0
Ethernet Inputs/Outputs: 1/0
Radio: AM/FM with HD Radio; SIRIUS Satellite Radio ready
Dock Terminal for Compatible Accessories: 1
Optical Inputs/Outputs: 2/1
Coaxial Inputs/Outputs: 2/0
Analog AV Inputs/Outputs: 5/1
Component Video Inputs/Outputs: 2/1
Composite/S-Video Inputs/Outputs: 5/5/1/1
Multichannel External Decoder: 8 channels
Yamaha AVENTAGE GUI
View App Screens
Impedance: 8 ohms
