I usually mount the hinge to the door first. Then set the door into the opening using a spacer on the bottom to get the right opening. Mark the hinge location on the cabinet side with a pencil or something. Then open the door just enough to get the drill in there while using the spacer to keep the door at the right height. Double check against your pencil mark and drill away.
Edited by BllDo - 1/24/13 at 8:39am
