AVS › AVS Forum › Audio › DIY Speakers and Subs › New DIY Sub Build Check
post #1 of 5
Hello,
I have been given a sub from a friend that he says it is an old sub from a 12" SVS (waterheater type) subwoofer and I want to build a 20hz vented box for it. the sub itself looks to be brand new and clean. I have been looking over all the other builds and here is what I come up with and want to make sure I am on the right track.
4.5 cubic foot enclosure
oAudio 500watt plate amp
4"x15" flared vent
and the sub specs I was given are:
Fs: 25.86 Hz
Qms: 4.11
Qes: 0.63
Vas: 69.66 ltr
Qts: 0.55
Re: 4.12 ohms
Cms: 0.233155 mm/N
Xmax: 19.2 mm
Rms: 6.42 ohms
James
post #2 of 5
that looks just fine. it will have about a 20hz tuning and depending on the eq in the amp, it may have some boost or not. i'd suggest an amp with a high pass filter to protect the driver under tuning. 500 watts is about the right amount of power to push the driver to its excursion limit in that cab.
post #3 of 5
thanks for the input. is there another amplifier you would recommend? I would like to keep the cost around $250 if possible.
thanks
James
post #4 of 5
i'm not one to ask about the available plate amp options. i'm sure someone will post some options.
the o audio appears to have a 20hz high pass filter option. should work.
http://www.oaudio.com/docs/subamp_variouseqsettings.pdf
graph 3b - 20hz setting - peq 'off' (or not used to extend response) looks nice. that will work with most room gain to give you a flat response to a hair under 20 hz.
then you can use the peq to beat down the largest modal peak, which will make it sound much tighter/faster/cleaner (pick your adjective) once in your room.
post #5 of 5
I have been thinking that I might want to increase the size and tune it to the 16hz range. should I stick with the oaudio amp or will the PE 500w bash amp be better?
thanks
James
