AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › need flat subwoofer cable wire for denon 4311 avr to two HSU ULS-15 subs?
post #1 of 6
have denon AVR 4311 and two HSU ULS 15 subs and need flat subwoofer cable to run across wood floors underneath rug. the subs are about 20-30 ft away from AVR. wireless is not an option as it interferes with my wifi
can I use flat speaker cable or do I need a flat cable for subwoofers?
is there a difference between speaker and subwoofer cable wire?
any suggestions/recommendations or am I posting in wrong thread?
post #2 of 6
Signal cable should be shielded to reject any EMI noise and interference, and speaker cabled is not shielded.
Googling stuff like “flat coax” and “flat shielded cable” isn’t getting much beyond those little adapters they use to route coax through windows.
But keep in mind that if you did find some suitable cable you’re probably going to have to buy it by the foot and install your own connectors on the ends. Can you solder?
An alternative that might work would be to use a flat HDMI cable and a couple of HDMI to RCA converters. Looks like a pricey option though, as you'll need two of the adapters, and I don’t know if HDMI cable is shielded.
Wayne A. Pflughaupt
post #3 of 6
Install the correct cable in the walls, under the floor, above the ceiling, and/or behind baseboards/crown molding.
Most cables will fail eventually if walked on.
post #4 of 6
Here is a great write-up that a kind and helpful AVS forum member did.
http://www.hometheatershack.com/foru...e-theater.html
post #5 of 6
Bmp for Wayne A. Pflughaupt
post #6 of 6
Thanks for the kind words, Neurorad!
Wayne A. Pflughaupt
  Back to Forum: Tweaks and Do-It-Yourself
