AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Recommendations on a 55-60" TV
post #1 of 6
Hi guys,
I am in the market for a new tv, 55-60". We have a fairly large living room where the viewing distance in some spots is > 15ft. I was thinking a 55-60" would go good in that room.
I'm looking in the $1000-$1500 range. I do not care about 3d at all, and LED lighting is not too much of a concern to me. If a good quality regular LCD 1080p, I would be totally fine with that.
At Costco, they have the Sharp Aquos LC-60LE633U on sale for $1400. Looked for some reviews online and it seem ok. What are you guys' recommendation in this price range?
Thanks in advance.
post #2 of 6
There is also a LG 60PV450 available at Sears for $1200. I would however prefer a LCD/LED over a plasma due to the IR issues and break in period which i've been reading about.
What do you guys think? Any suggestions?
post #3 of 6
At 15 feet go as big as you can, a 70 inch Sharp at that distance would be nice.
For $1000-1500 your going to get a second tier big screen. Get the Sharp 70e735, not sure how much it is but as I said at 15 ft, you need a bigger screen.
I watch my 55 inch at 8ft and wish I would have bought a 60 inch .
post #4 of 6
the 70" is getting on the expensive side. I am kind of on a tight $1500 max budget. At $1400, i think the 60le632u is pretty good deal.
what you guys think?
post #5 of 6
also anyone know the difference between the 60le632u and the 60le633u ? both seem to be the same tvs but different model numbers..
post #6 of 6
60le632u is not a bad choice. however if you could chip in a little more for 60le830u would be great! comparison here, http://tv-compare.blogspot.com/2011/...-60le830u.html
