AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › Hauppauge HD PVR IR Blaster and Directv H21-200
post #1 of 2
I have an HTPC with a Hauppage HD PVR connected with the included IR blaster attached to a Directv H21-200 (HD Receiver).
I configured the blastcfg program by using the learning feature for using the Directv remote.
When using Windows Media Center, however, I can't change the channels appropriately. I am quite sure it has something to do with the settings in blastcfg (Blaster Configuration), but just can't figure this out
Any ideas what to put into the following settings?
1. Min. Digits to Send
2. Inter-Digit Delay (ms)
3. Power On Delay (ms)
4. Key Delay (ms)
5. Tuning Delay (ms)
6. Single Digit Delay (ms)
7. Send 'Power On' before Channel [Yes or No]
8. Send 'Enter' after Channel [Yes or No]
9. Use Major Minor Channel Format [Yes or No]
Thanks for any help!
post #2 of 2
Did you ever get this to work? I have the same setup.
