I've managed to get my HD2600XT to display OK on an old CRT TV via SCART RGB at 720x480@50i with Powerstrip using the following settings:
"720x480" 15.101 720 770 842 968 480 505 510 564 interlace +hsync +vsync
which looks like this in Powerstrip:
http://www.idiots.org.uk/vga_rgb_sca...resolution.gif
I thought I might be able to get the PC to default to these settings by modifying the EDID info, but that didn't work. Obviously there's no actual EDID info sent from the TV, and XP only identifies "Default Monitor" and "Generic TV" (I think the latter applies to the S-Video TV output), but I used Monitor Asset Manager to generate the EDID line for the above settings and copied that into the registry for the two display entries. Before this the only option in CCC was 60hz and after there were some extra choices (I think they were 47hz and 56hz) but not 50hz strangely. Either way, the TV's out-of-sync until I load Powerstrip and it sets the right timings.
So is there any way to default XP to the correct settings, or do I just have to use Powerstrip?
Also, should I be able to go to 720x576 or 768x576 as I thought I read that would work (and the former is the PAL SDTV standard I believe) but when I try, it's in sync but kind of zoomed in so that I can only see the center of the desktop. I used the following timings:
"720x576@25i" 13.5 720 732 795 864 576 581 586 625 interlace +hsync +vsync
"768x576@25i" 14.75 768 789 858 944 576 581 586 625 interlace +hsync +vsync
