AVS › AVS Forum › Video Components › Home Theater Computers › Tweaking VGA->SCART RGB timings
Tweaking VGA->SCART RGB timings - Page 2
post #31 of 44
By the way joe, you might want to look at using MediaPortal for playing video, as that can automatically switch the refresh rate to suit whatever video your playing (either by switching to a defined modeline or sending a command to Powerstrip to switch).
Media Player Classic - Home Cinema can also auto-switch to a defined modeline, but I don't think it supports Powerstrip, so if you don't need all the features of MediaPortal that's another option.
post #32 of 44
reply to doveman
It's cool being able to get a great picture out of a CRT TV isn't it
Yeah, you're right.
I'm setting up this HTPC for someone who's only got a CRT TV
Okay that means you need 4/3 resolutions.
Here are some.
And tell your friend about that it is possible to play 640x480 and 800x600 fullscreen PC games using this type of connection.
PowerStrip can be set up for this. You just have to add 640x480 and 800x600 as custom resolutions.
The modelines are in the article linked above.
That sounds good. I'm watching most of movies at 640x480i@60Hz or 720x540i@50Hz. I have not discovered any disturbing effect during playback.
joecontra
post #33 of 44
Actually it's a widescreen CRT TV, which is why I've setup WS resolutions/timings...with a lot of help from sneals2000
Thankfully, I'm using ATI graphics, so didn't need to build any composite sync circuit.
post #34 of 44
I saw someone who turned on the csync on his ATI card, and the whole picture disappeared. He had to build the circuit.
Now I understand. What resolutions are these? I also could give some if needed.
joecontra
post #35 of 44
Yeah, I think I read some ATI cards do need the circuit. Not sure which ones though. I've only tested with an HD2600XT card and HD3200 IGP.
I'm using:
1024x576 @50Hz
844x480 @60Hz
I haven't got the PC connected at the moment, so I can't check the exact timings, but I think for 1024x576@50hz I ended up with something like:
Horizontal:
Scan Rate 15.625
Total line 1260 pixels
Active line 1024 pixels
Line sync width 93 pixels
Front porch 32 pixels
Back porch 111 pixels
Vertical:
Refresh Rate 24.999
Total line 625
Active line 576
Line sync width 5
Front porch 5
Back porch 39
post #36 of 44
I'm using:
1024x576 @50Hz
844x480 @60Hz
Horizontal:
Scan Rate 15.625
Vertical:
Refresh Rate 24.999
Total line 625
Active line 576
Line sync width 5
Front porch 5
Back porch 39
Thanks for the info. If you could check it exactly I would show it on my site if you don't mind.
joecontra
post #37 of 44
Sure, will do.
I might try some of the settings on your site for 4:3 modes as I could never get the picture to fit (it was like it was majorly zoomed in) on the TV with the settings I was using before, but I'm not too bothered as this PC's only going to be used in 16:9 anyway.
post #38 of 44
OK, the figures I gave for 1024x576 @50hz are correct. The following is for 854x480 @60hz:
Horizontal:
Scan Rate 15.735
Total line 1066 pixels
Active line 854 pixels
Line sync width 85 pixels
Front porch 21 pixels
Back porch 106 pixels
Vertical:
Refresh Rate 29.971
Total line 525
Active line 480
Line sync width 31
Front porch 2
Back porch 12
post #39 of 44
Horizontal:
Scan Rate 15.735
Vertical:
Refresh Rate 29.971
Total line 525
Active line 480
Line sync width 31
Front porch 2
Back porch 12
Have you tried my settings?
joecontra
post #40 of 44
I'm afraid I don't have a suitable TV to use at the moment, so can't do much until I get hold of one.
post #41 of 44
Hi!
I managed to build a VGA-SCART cable in Plug and Play version.
The article is coming soon.
joecontra
post #42 of 44
There appears to be an issue with switching resolutions whilst Mediaportal is running, so I might have to run it always at 1024x576. Is it possible to set up 1024x576@50hz and 1024x576@60hz modes?
post #43 of 44
Running 576 lines mode at 60 Hz would bring a KHz value that the TV cannot handle.
joecontra
post #44 of 44
joecontra
Ah, thanks, no worries then. I doubt MP will be made compatible with switching resolution (as most people just run it at one resolution) so I'll just have to run it at a constant 1024x576@50hz.
