AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo TX-NR3009 TX-NR5009 Spec's just realesed
Onkyo TX-NR3009 TX-NR5009 Spec's just realesed - Page 10
post #271 of 320
New firmware available to download on the 5009.
post #272 of 320
any idea what it does
post #273 of 320
Callback action March 19th 2012:
Onkyo has a callback going on for several AVR models of the year 2011 generation due to sub standard parts. The 5009 is among those.
You should check, if the 5009 you have is among those, who have to be serviced. This refers among others to all 5009s units manufactured between November 2011 and January 2012. Check with you local Onkyo distributor, if your unit is affected.
PS.:
Here is the link to the Onkyo UK site.
http://www.uk.onkyo.com/en/articles/...ice-80521.html
post #274 of 320
post #275 of 320
PS.:
Originally Posted by dowop View Post
Same info on the U.S site.
http://www.us.onkyo.com/press_releases.cfm?id=253
I wonder if Integra models are affected as well?
post #276 of 320
could be a kind of catch 22 for Onkyo if they are. just making a stronger case for the similaraties between the two except for a few features they offer to make them slightly different.
post #277 of 320
Affected Onkyo Models:
TX-8255 TX-8050 HT-RC360
TX-SR309 TX-NR609 TX-NR709 TX-NR809 TX-NR1009 TX-NR5009
(HT-R390) HT-S3400
(TX-NR609) HT-S7409&HT-S8409
What could all this units have in common ?
The price range is fairly large..
The spike in onkyo bad press is really turning me off, I'm afraid to recommend onkyo to a friend. I think my 3007, though all good, will be my last onkyo..
post #278 of 320
Did you check the Integra site ?
There shouldn't be any difference, because of same boards.
post #279 of 320
(HT-R390) HT-S3400
Well if Onkyo had a component issue, if they source various power supplies from one manufacturer for example, it makes perfect sense why the 3009 and Integra models are exempt at this point in time. They dont make every model every day
post #280 of 320
Except i have a brand new 3009 doing exactly what the recall described! Shuts off right away
post #281 of 320
Yea i cannot find anything on the integra website pertaining to this recall.
post #282 of 320
As Interga is more of a specialty shop line do you think Onkyo might be being more low key with the integra line and just working this issue thru its authorized dealers. Just a thought .
post #283 of 320
If it was indeed a parts/component issue, it makes perfect sense why the Integra line might not be involved..
The 80.3's were on back order until recently.. which would indicated a manufacture date outside of 11/11 and 12/11..
post #284 of 320
What you say makes a lot of sense and mabey there truly is a quality difference internally in the Integra over the Onkyo line.
post #285 of 320
Just to be clear... that's not what I'm implying at all.
They get parts, build a certain amount of units... wash rinse repeat... because the Integra line isn't "mass market" they may indeed not share any of the bad batch components causing this issue.. but these units are almost identical in every way that counts (i.e. 3009/5009/80.3, etc..)
post #286 of 320
Filmmixer:
My comment was basically an attempt at sarcasim. I have owned a 5007/5008 than Integra 40.3 50.3 and now the 3009. I personally have not heard any discernable differance in the audio quality, or build in either the Integra or Onkyo. So I would agree with your clarrification Timing more than anything else. I do repeat it is a shame that Onkyo had another issue calling a recall second generation in a row. Does not build a lot of confidence in future buyers but than again they acknowledge the issue and take care of it. We accept this from the auto industry as a normal part of the industry.
post #287 of 320
I just saw this and laughed
Every year they have issues....that require you to either send the unit back,like last years issues..or some of the older models with the HDMI board issues that would basically brick the receiver...due to the out of warranty repair cost
They replaced a faulty 905 receiver I had a with a 5009...which I have basically never used..its in a box in my garage
It was one their very early production models
I guess I need to call their "wonderful" customer service and get a RA number
LOL...some things never change
I did enter my receiver number on the website and it does say "your receiver does not need this update"
Time will tell...
Warren
post #288 of 320
Time will tell...
Warren
How would you know, you say ""its in a box in my garage"" ??
post #289 of 320
I guess time will tell when it rusts in the box in his garage.
post #290 of 320
the resealed box in my garage has the serial number on the out side of it....like any recent manufacturers AVR's boxes that I have seen
I only pulled the unit out months ago to check for shipping damage when Onkyo took back my defective 905...I ran it for 15 minutes and put it back in the box
In the time it took to get that whole defective 905 madness straightened out I had already bought another AVR...
Simultaneously I was obtaining an RA number to send back my 5508 preamp for last years "wire" replacement ordeal
So..Onkyo was not on the top of my credibility list at that time..as you can imagine
Anyway
I copied the serial number from the 5009 receiver box and input the number into the website
Warren
post #291 of 320
I retaped the box shut...hopefully it hasn't rusted in the 6 months it has been sitting there in a sealed box?
ironically...speaking on avr's sitting in my garage
I ran across an Onkyo 875 the other day...the owner said the video processing wasnt working...he was told the HDMI board had gone out
I am sure many know here how typical that repair is on those units and a few other recent Onkyos...I myself have had that repair done under warranty when I had an 875 a couple of years ago
My understanding is that a paid repair is about $700-900
Anyway...long story short...I give him $40.00 for it...thinking I would use it to power some speakers in the garage or whatever
I think the amp section in those units is top notch
And then what do you know..I hook it up and it works perfectly video and all..LOL?
For now anyway...time will tell..I dont need the video processing for what I was thinking anyway
So it is now sitting in a box on top of the 5009 receiver in my garage
Warren
post #292 of 320
Warren
Me to, my very old onkyo 501 amp and 3200 pre still work like new and my 3007 is all good. But at this time I would think twice about another onkyo, don't want to press my good luck. I'm waiting to see what the next 3009, 5009 replacements are all about, what will onkyo cut out and add to the specs and features. Onkyo removed the BTL amps, which is the mode I use on my 3007. The #1 reason I got one!
post #293 of 320
I see some new models starting to trickle out on their website
One thing I can see is some enhanced menu functionality
The higher models wont hit for a couple of months..so again..time will tell
Warren
post #294 of 320
Integra has issued a recall for the same issue for the three lower moldels. so far.
post #295 of 320
were the Integra's the subject of last years replacement wire recall as well?
Warren
post #296 of 320
Warren
I do not remember
post #297 of 320
Warren
Hi turnne1, yeap ... DTR-40.2, DTR-50.2, DTR-70.2, DTR-80.2, DHC-40.2 and DHC-80.2 models.
post #298 of 320
All these similar problems that do exist major or minor just leans toward convincing me that the differences between the integra and onkyo lines are not that vast. Although there seems to be no issues with the 70.3 or 50.3, or 80.3 yet. Love my 3009 but just holding my breath.
post #299 of 320
I was playing around with the picture settings today on my integra dtr 80.3 and found something interesting. When setting the picture mode to "through" the only processing is supposed to be upscaling to 1080p for that particular input. At least for me the "through" setting also changes the color temp to a warmer setting. I paused a screen via my directv that had white wording and changed the pic mode from direct to "through" and every time i changed to "through" the whites had a noticeably warmer tone to them than via direct mode. If i then change the mode to custom, 1080p and color temp normal then everything looks the way it should again. So it appears the that the "through" setting is also setting a warmer color temp along with upscaling. Does anybody else see this behavior since the Onkyo uses the same video processor?
post #300 of 320
It's also possible your custom setting may be making the picture cooler. The only way to tell for sure would be to bypass the Onkyo entirely and run the HDMI directly to the TV from the source.
