I found a solution that is working and is so low tech!
A power strip that has some switched outlets, controlled by one main outlet. I have the Onkyo receiver as the switcher and the amps are in the switched sockets. When I hit the power macro on the tablet and it turns on the receiver, this outlet strip supplies power to the behringers. As long as I leave the rocker switches in the 'ON' position, they are now controlled via the tablet! Simple and cheap solution as long as it holds up over time.
... and doing the job right. The good news is that the Furman will last a lifetime and you can relax about it rather than worrying whether the smart strip is going to burn out.
I do know it was a commercial insulation and maybe refrigeration place, not a retail store front. It was cheap, $6 a sheet.
