Originally Posted by mike1812
That's a separate topic - let's deal with your setup first. There are a number of threads on here about pre-wiring - if you put enough in up front to accommodate different solutions, then you are good. My biggest concern would be what if you home run the wire to one location, but the buyer wants to place the central location elsewhere. There's a lot of pros and cons to what you plan to do - I suggest a separate thread for that. And unlike what you did, in the condo you should ALWAYS run rg6 to room locations.
Not sure I understand the question? Will this work for the IR? What are you asking? The expander (1176) is used to add additional outputs to the 562 matrix. Your 562 matrix can take in 6 sources, and send out 6 signals via ethernet plus 1 local signal over component/analog/digital audio. The 1176 ADDS another 6 outputs via ethernet, meaning you can have 12 + 1 zones with the system you have purchased. The (2) 1109's offered to you were used to "inject" IR control signals into the 12 ethernet output signals (6 per 1109). Without the 1109's, you have no control built-in to the distribution matrix, you have to use another means of IR control. However, bear in mind that using an 1109 or its newer version 1109A MAY not be the best solution. We should at some point talk about control of everything and the best means to accomplish it within your budget.
Thanks Mike...
I've been crushed at work, so I'm just getting back to my project (have to be moved in my Oct. 1, drywalling and hardcoat plastering going on now.
I will get the 562 and 1176 any day now. Still looking for wall plates. The fellow left them by mistake and then had a death in his family, so he mentioned he will be seeking them out. Otherwise, I'll be buying... source for decent price. All seem to be in the 180 range and I'll need 5 min.
Other items:
As you may remember... I have 5 cat5e run to each location. There is a remote possibility (no pun intended) I can have some Cat 6 run also... should I and how many of each... I spent a lot on cat5e already, like to leave some... reason behind using cat6?
I would assume that I will be running the LR set over an HDMI transmitter and receiver... through my AVR rather than the matrix... am I correct. So here's where I am...
Im confused about the LR set and how it ties in to anything else here.
Im looking for an IR/Remote solution.
I saw this for the PS3 http://www.audioauthority.com/page/c_1071_app
is it a possibility for extending it?
I was thinking I could keep the ps3 in my kids room and run it back via two of the 5 cat5e through the AA item to the LR set.
Hope you're enjoying the long weekend!
So jealous!!! Said last year I was going to try to go this year, but alas, work has been 90mph all year long. Feel free to pm me to not derail this thread, but curious to know what you see there. Anything in particular you are scouting? My next phase is automation and lighting. Have fun!
