I have a dedicated Home Theatre room of dimensions 19 ft (length) x 14ft (width) x 9ft (height). I have a 110 inch projector screen with a 5.1 Elac (German brand) speaker system powered by an Onkyo 605 receiver and my HTPC. My walls and ceiling are concrete and has not been acoustically treated yet.
I am not happy with the sound clarity of my speakers. I believe that my speakers are generally "soft" in nature and not as bright or punchy as I would expect it to be, though the volume output is quite good. Also, dialogues are not as clear as I wish it to be. I saw a similar 5.1 setup at a friend's place who also has untreated walls but has Energy speakers paired with a Marantz receiver. I was quite impressed with the quality of the speakers, especially the brightness, sharpness and "punch".
I consulted with a acoustic specialist who, while acknowledging that my speakers were "decent but not as good as Energy" recommended that I should treat my ceiling and side walls first. He recommended acoustic panels for the full wall width and height, and ceiling panels for only first reflection areas. He also recomended a carpet for the floor and leaving the front and rear walls untreated to create some reverb and avoid full dampening.
Here are my questions:
1. The acoustic treatment is very expensive (taking into account installation and finish quality) and costs around $2000. Am I better off investing this kind of money on new speakers rather than on the room treatment? After all, my friend has a similar setup and his speakers sounded good without any acoustic treatment.
2. Is the suggested treatment correct? I read the forums and most have recommended that only first reflection points need to be treated, not the entire side walls or ceilings. However, this specialist says that its better to treat the entire side walls and instead leave the front and rear walls untreated. Going by the forum recommendations would significantly bring down the cost for me, though the finish may not be as good as sporadic panels would be seen here and there (first reflection points only).
Suggestions on how I should proceed will be most welcome. I don't want to spend a bomb on room treatment and then discover that my speakers weren't "good enough" to begin with!
