Originally Posted by
penngray
The OP asked for SIMPLE and LOW COST treatment suggestions. He later posted that all this discussion is just too confusing for him (which I agree with him). You still think many like the OP need to complete a first year acoustical training course to treat their rooms. The OP like 99% of the population do not have the time or the passion to learn about acoustics they would rather trust someone with experience to tell them....
yes, and i gave a solution for a cheaper and more effective porous bass trap than what you offered. you ignored it.
again, thank you for taking this to polar extremes. taking 20minutes or a few hours to gather an understanding of basic problems (fundamental issues) in small room acoustics before spending money blindly on 'treatments' is not the same as a "complete a first year of acoustical training". you exaggerate to make some sort of point. my preference is not to blindly offer solutions to buy if the user doesn't even know what issues those solutions are there to solve. if the user doesn't want to take a few moments to read why they are applying treatments, then they can ignore the text and blindly whip out their credit card to purchase solutions.
this is why manufactures of such products exist - as they provide a service to the customer to explain the issues and what recommendations for a user's room.Quote:
penngray
They can decide if that will work in their room, they can put them on the wall, listen and or measure.
Then take them down listen and measure. They will know the differences and there is a very, very, very high probability that they will love the difference it makes. Because there is a long, long, long list of success stories.
penngray, one more time ... what measuring tool will one be using to determine the effectiveness of early reflection absorbers? you keep saying you're measuring or doing "proper measurements". what tool are you using?? how does one verify that their absorbers are effective in attenuating an early reflection (eg., how does one know whether their panel needs to be made thicker or with a larger air-gap?)
penngray
Heck almost every acoustical site has a picture of some room with treatments EXACTLY like we have explained.
the funny part is, you seem to think that i am against attenuating early reflections. if only you could find a single quote where i state otherwise... post 3 of this thread makes a pretty heavy claim
for the attenuation of early reflections.
the difference is, absorption is only one way to attenuate an early reflection. some room models require as much sonic energy as possible for the termination of the ISD --- and absorption at early reflection points defeats this purpose. absorption is not a requirement to attenuate early reflections, as stated again in post #52. this may not be relevant to this particular user, but it in no way makes the claim false!
penngray
GIK rep just posts a video showing pretty much what we have recommended too. Feel free to tell him that room is just "Guessing" at the refections like you have been posting/telling me.
one minute you say measurements are required - the next minute you insist that placement based on what everyone else is doing is good enough.
as i've stated too many times to count, the mirror-trick is guesswork for approximate physical location of a geometric reflection point for specular energy. the mirror-trick
does not tell the user if the reflection has been attenuated to a particular gain based on user design requirements. do you understand the difference between placement and measuring the effectiveness of a panel? they are two entirely different concepts. the mirror trick doesn't tell you anything about how effective a panel is.
GIK's customers probably aren't measuring - so the mirror-trick is a good approximation.
however, you keep insisting on taking measurements. so tell me - if you already love to take measurements and have the equipment, then why on earth would you refuse to actually take measurements for your specular absorbers to make sure they are placed in the proper location to be effective for the entire listening position, and to also make sure the panel is effectively attenuating the reflection to a required gain?
you seem to pride yourself on measurements except for absolute refusal to measure regarding this one very aspect!
penngray
I really believe you do not understand the audience. The audience is trying to buy a battery at Walmart and you are trying to teach him about cold fusion. Take a step back and realize the goals of the thread.
then they can ignore the commentary and move on. what's the difficulty in that?
it isn't "cold fusion" to understand how porous absorption works and where it is to be placed in order to be most effective.
